For Sale/Looking For => Parts for Sale/Wanted => Topic started by: the caveman on August 01, 2009, 09:24:15 am
Sorry about some of the poor pics,I will try to describe what there is. All prices +shipping and handling. I will negotiate.
Silver faced cluster Mk3 .Gasser tach doesn't work. Can be made to fit your diesel cluster $35
(http://i356.photobucket.com/albums/oo4/lhomme/DSC02215.jpg)
1.6 D alternator Tested recently $25
(http://i356.photobucket.com/albums/oo4/lhomme/DSC02212.jpg)
(http://i356.photobucket.com/albums/oo4/lhomme/DSC02210.jpg)
1.6 D starter Tested recently $25
(http://i356.photobucket.com/albums/oo4/lhomme/DSC02209.jpg)
1.9 AAZ mk3 alternator 70 amp.Tested recently $35
(http://i356.photobucket.com/albums/oo4/lhomme/DSC02208.jpg)
ALH valve cover, coolant flange ,vacuum pump $10 each
(http://i356.photobucket.com/albums/oo4/lhomme/th_DSC02178.jpg) (http://s356.photobucket.com/albums/oo4/lhomme/?action=view¤t=DSC02178.jpg)
ALH oil pan and cracked but decent plastic cover $50.
(http://i356.photobucket.com/albums/oo4/lhomme/th_DSC02181.jpg) (http://s356.photobucket.com/albums/oo4/lhomme/?action=view¤t=DSC02181.jpg)
2[only !] TDI pistons and rods. Good shape, timing belt damaged the 2 others $20 for both.
(http://i356.photobucket.com/albums/oo4/lhomme/th_DSC02190.jpg) (http://s356.photobucket.com/albums/oo4/lhomme/?action=view¤t=DSC02190.jpg)
Mk 4 brake master and ABS control unit $15 for the master, $75 for the ABS unit
(http://i356.photobucket.com/albums/oo4/lhomme/th_DSC02203.jpg) (http://s356.photobucket.com/albums/oo4/lhomme/?action=view¤t=DSC02203.jpg)
large ridiculous volvo gasser intercooler. Will hold up to 15 lbs, but think of how much cooling! $ 40
(http://i356.photobucket.com/albums/oo4/lhomme/th_DSC02174.jpg) (http://s356.photobucket.com/albums/oo4/lhomme/?action=view¤t=DSC02174.jpg)
Pick a water pump ! 1 old style 2 newer, all good, $10 each
(http://i356.photobucket.com/albums/oo4/lhomme/th_DSC02179.jpg) (http://s356.photobucket.com/albums/oo4/lhomme/?action=view¤t=DSC02179.jpg)
2 special shaped diesel coolant hoses $5 each
(http://i356.photobucket.com/albums/oo4/lhomme/th_DSC02180.jpg) (http://s356.photobucket.com/albums/oo4/lhomme/?action=view¤t=DSC02180.jpg)
2 turbo intakes, 1 with vacuum hose fitting for LDA, 1 with large breather inlet, both $15, 2 turbo exhausts, 1 TD [sorry don't which kind] $15,other is a JX/Quantum style $65
(http://i356.photobucket.com/albums/oo4/lhomme/th_DSC02182.jpg) (http://s356.photobucket.com/albums/oo4/lhomme/?action=view¤t=DSC02182.jpg)
power steering pumps and brackets,1 older alternator bracket $20,the pump and bracket set $100, TDI ps pump $30
(http://i356.photobucket.com/albums/oo4/lhomme/th_DSC02183.jpg) (http://s356.photobucket.com/albums/oo4/lhomme/?action=view¤t=DSC02183.jpg)
covers $10 for lower cover, $5 valve cover [with the 2 reinforcements]
(http://i356.photobucket.com/albums/oo4/lhomme/th_DSC02185.jpg) (http://s356.photobucket.com/albums/oo4/lhomme/?action=view¤t=DSC02185.jpg)
manual clutch cable ,dipsticks $5 each
(http://i356.photobucket.com/albums/oo4/lhomme/th_DSC02186.jpg) (http://s356.photobucket.com/albums/oo4/lhomme/?action=view¤t=DSC02186.jpg)
Turbo oil feed lines, 1 is AAZ 1 is 1.6TD $15 each
(http://i356.photobucket.com/albums/oo4/lhomme/th_DSC02189.jpg) (http://s356.photobucket.com/albums/oo4/lhomme/?action=view¤t=DSC02189.jpg)
had an accident in the front? here's a front mount bracket $7
(http://i356.photobucket.com/albums/oo4/lhomme/th_DSC02191.jpg) (http://s356.photobucket.com/albums/oo4/lhomme/?action=view¤t=DSC02191.jpg)
1.6 na head. good shape,straight and came from motor with good compression $65 [i will remove the manifold to ship]
(http://i356.photobucket.com/albums/oo4/lhomme/th_DSC02192.jpg) (http://s356.photobucket.com/albums/oo4/lhomme/?action=view¤t=DSC02192.jpg)
Crank breather ,vanagon diesel oil filler $15 each fIller neck SOLD
(http://i356.photobucket.com/albums/oo4/lhomme/th_DSC02194.jpg) (http://s356.photobucket.com/albums/oo4/lhomme/?action=view¤t=DSC02194.jpg)
and finally good used crank bolt $50 ;D
(http://i356.photobucket.com/albums/oo4/lhomme/th_DSC02204.jpg) (http://s356.photobucket.com/albums/oo4/lhomme/?action=view¤t=DSC02204.jpg)
I guess since you posted it I will take the oily looking TD intake with the LDA hose fitting. And I would love to have that crank bolt, but I already got some so someone else is going to be the lucky one ;)
I will send a PM as well.
Interested in both turbos and the aaz head. How much is shipping to 43402?
I can use the ALH valve cover, how much for shipping 22427?
PM sent
pmed
interested in the quote email me [email protected]
PM Sent!!
Pm sent for the vanagon oil filler!
still have newer water pump? does the pump work and is the thermostate in the pump??
Sorry .Just replying to myself to bring this post back to the top
Parts recieved and as described A++
sent you a message..
Thanks for the endorsement !
hello, i'm interested in the 1.6l na head. i need one with 12mm head bolts and solid lifters and no cracks between the valves
thanks
I thought ALH valve covers were the three-stud kind like the AAZ?
Polish up that crank bolt if I throw in another $10? ;D
$50 for a used crank bolt?? :o
you wouldnt happen to have a ALH egr valve? good or bad? im looking for a spare one to remove the egr stuff and keep my good one as a spare.
The ALH are mk4 TDi with the aluminum VC. Maybe you are thinking AHU?
$50 for a used crank bolt?? Shocked
Okay just for you i want $65.
you sir, are a tool.
;D ;D ;D
thanks
Hydralic head, not mechanical.
