Engine Specific Info and Questions => IDI Engine => Topic started by: ohc on July 21, 2009, 07:16:30 pm
Anyone know the two hex sizes for the pivot points holding the AC Compressor. Hopefully can save me a couple skates to the hardware store.
Thanks.
Should be 8mm and 6mm IIRC.
They are 10mm
if your just loosening to adjust the belt, don't completely back them out, because they are a pain to get back in (hard to line up...)
you can buy a set of 12 hex sockets from harbor freight for 12.99 and it should have the sizes you need.
Mine are 6 and 10.
And to get timing things done, i don't need the AC compressor out, just the belt off, correct?
Correct!
