Engine Specific Info and Questions => TDI Engine -General Info => Topic started by: midwestfalia on July 01, 2009, 08:46:05 pm
Title: where are these air bubbles coming from?
Post by: midwestfalia on July 01, 2009, 08:46:05 pm
I replaced my fuel filter about 2k miles ago (98 jetta AHU) and have had minor starting issues ever since.  I filled the filter to the rim before installing.  The motor started up with about 10 seconds of cranking.  It takes about 3-4 seconds every time now. It used to fire up with a bump of the key.  I get hundreds of small bubbles in the clear line going into the pump.  I have checked all the fittings and hoses and cant find anything.  I did completely remove the plastic preheater regulator T fitting from the fuel lines to clean it when putting the new filter on.  Does this keep pressure on the fuel returning to the tank?  Would installing it backwards cause any issues?
(http://i717.photobucket.com/albums/ww179/powdercore/Fuelfilter.jpg)
Title: Re: where are these air bubbles coming from?
Post by: Quantum TD on July 06, 2009, 05:09:02 pm
What brand filter did you buy? If you bought anything other than Bosch or Mahle, throw it away and buy a good one. There's been a rash of crappy Chinese filter problems.
Next. The filters don't come with the plastic part held in place with the clip. You may have cracked it when removing it, or (as above), it may not fit the filter properly. Also, check your rubber lines and clamps. If the rubber is stiff, or the clamps are loose, they'll let air into the filter.
Post by: Vincent Waldon on July 06, 2009, 06:19:27 pm
You can also check to make sure the o-ring is in place and in good condition... ideally they'd ship new filters with a new one.  A bad o-ring is a pretty common source of air after a filter change,
Post by: diesel smoke on July 07, 2009, 07:57:19 pm
Wix filters come with a new o-ring for the regulating valve. ;)
Post by: Vincent Waldon on July 07, 2009, 08:10:09 pm
Wix FTW !!!
Having said that, I'm pretty sure my TDI would spit out anything that's not German.  ;D
Post by: smutts on August 27, 2009, 12:22:03 pm
The little "o" ring for the filter is favorite. Mine was singing as air was sucked in when the engine was turned off. >:(
Why when using "Babelfish" does the fuel heater valve get translated as a "frog" from the german? ??? Bizarre!
