Engine Specific Info and Questions => IDI Engine => Topic started by: sour diesel on June 19, 2009, 08:05:16 am
Title: options for clutch/flywheel upgrades?
Post by: sour diesel on June 19, 2009, 08:05:16 am
Hey all new to these boards & must say brilliant source for everything diesel, love yall. Anyway im looking for upgraded clutch & flywheel options for my fn code 1983 td rabbit. please any tips will be appreciated. cheers
Title: Re: options for clutch/flywheel upgrades?
Post by: gigaz2 on June 19, 2009, 10:12:15 am
on a 085 type gearbox? stock TD parts handle pretty much all the torque you can throw at them with a 1.6 engine
mega upgrade:
020 type gearbox, G60 transmissions, G60 flywheel and vr6 clutch
pretty bombproof until things get really interesting on the engine side (250hp++)
Post by: vanbcguy on June 19, 2009, 06:24:26 pm
Is the VR6 clutch/flywheel a direct swap in for the 020 behind a 1.6?  (timing marks are different obviously)
Post by: theman53 on June 20, 2009, 08:04:06 am
There are other options, but something like this could be a real on off switch. I went with a 1.9L pressure plate, but this is available for a 1.6L as well.
(http://c4.ac-images.myspacecdn.com/images02/105/l_3eb0fe615ee0489583608a20b6f84c53.jpg)
Post by: sour diesel on June 20, 2009, 05:21:31 pm
I think what I really want to know is if my fn code 5sp trans will mate with 210mm small spline clutch & flywheel set up yhat bfi sells?
Post by: theman53 on June 20, 2009, 06:25:08 pm
I believe if it is 26 small spline then it should.
