Engine Specific Info and Questions => IDI Engine => Topic started by: Dean Erickson on June 12, 2009, 06:49:04 pm
Title: Governor mod spring
Post by: Dean Erickson on June 12, 2009, 06:49:04 pm
New to this fourm but not VW diesel engines. I have been looking at the old posts about the gov mod. There are a few diffrent views on what spring to shim and how much. What is the concensus on which spring to manipulate. From what I have read it's the main spring that needs to be changed or shimed ( the large one). Is there a stronger bosch spring that could just be changed out?  I am working a on a 1985 1.6 TD engine. This is my car a few of you may know me from VWdieselparts.com.
(http://i637.photobucket.com/albums/uu91/DieselDean113/000_1488.jpg)
Title: Re: Governor mod spring
Post by: rabbitman on June 12, 2009, 06:53:38 pm
I've heard of quite a few people that are unhappy with the gov mod.
IIRC it's the medium spring that gets shimmed, check in the FAQ though I could be wrong ;).
Post by: maxfax on June 12, 2009, 07:54:49 pm
I've been very pleased with the gov mod on my N/A....  I kept it fiarly modest though.. Been too long for me to remeber exactly which spring I shimmed, but it wasn't the small idle (?) spring..  At least it wasn;t the second time I tore the top off the pump...
Post by: Rabbit TD on June 13, 2009, 07:42:43 pm
I don't know about the spring but that sure is a nice looking car you have, it is a Rabbit isn't it ???
Post by: Dean Erickson on June 14, 2009, 07:30:32 pm
Yes A 1981 Rabbit I changed to round headlights and put in a 1.6 TD from a 85 Jetta. Just finished painting a few weeks ago. I have to change my clutch it's slipping so I will weight to do the gov mod. I am going to shim the main spring because that is the one the effects the upper rpms. I am also going to call my local Bosch service dept. an see if I can get a stronger spring. Here is a pic when I changed the front to round head lights.
(http://i637.photobucket.com/albums/uu91/DieselDean113/000_1326.jpg)
Post by: theman53 on June 14, 2009, 07:59:34 pm
You want to do the main "heavy" spring. I didn't do the intermediate spring, but others have and they say that there is drivability issues with the intermediate spring. I have done the main spring on 2 N/A s and have been very pleased. Not a hard mod, but not easy to compress that spring. I put about 1/4" of washers in mine, but I think you could go more if you wanted. I wouldn't do less than 3/16 or 1/4 though.
Post by: maxfax on June 14, 2009, 08:05:08 pm
Hmm me thinks I need to try some more washers... I was pretty conservative, I probably just barely have 3/16". Still some noticable improvement though...
Post by: 8v-of-fury on June 14, 2009, 08:32:34 pm
So doing the governor mod.. you are fooling the pump in to thinking it is theoretically spinning faster then it really is
(because that's how it does its junk, is to base fueling on spring compression, which is based on centrifical force. correct?) to make it pump more fuel at an earlier time in the RPM range? is that what is pretty much taking place?
It seems like it is a pretty easy to do mod with pretty good gains from something that anyone can do for practically nothing but a little time eh? I think i will do it on my pump once i get the diesel in there :)
Post by: vanbcguy on June 14, 2009, 08:55:17 pm
The "Main" spring is fully extended at all times under "normal" driving, it doesn't start to compress until you spin above 4K RPM.  Once it starts to compress it cuts fueling FAST which is why these cars seem like they hit a wall around 4200 - 4500 or so depending on the particular pump.
Shimming the spring is basically the same thing as using a stiffer spring.  In my mind a stiffer spring would be better, but shims are a heck of a lot easier.  What you are doing is increasing the RPM required to provide enough force to start compressing the spring.  Adding a few washers can push the limit up to over 5000 RPM pretty easily.
The tough part is you can't really "choose" what RPM you want to have the pump cut fueling at unless you have a test bench to do it on!
Post by: 8v-of-fury on June 14, 2009, 08:56:43 pm
Add one or two at a time and see what happens no? lol
Post by: maxfax on June 14, 2009, 09:23:08 pm
And when it blows up, back up one step!
Post by: Rabbit on Roids on June 14, 2009, 10:27:27 pm
i shimmed my main spring with 2 little nuts that fit on the shaft like a glove. my car spins some hellacious RPMS now. and BLOWS the black smoke. but yea, about a quarter inch of shims/spacers gives great results. and my pump is turned up to where i actually adjust the idle with the fuel screw, so its pretty much turned all the way up. but it was amazing the difference it made. anyone debating on doing this, should definitely do it. way worth the time.
Post by: maxfax on June 14, 2009, 11:32:58 pm
How thick were those two nuts Rabbit on Roids???   Tryin to get an idea of how far I wanna shim when I get the tiem to tear the top back off my pump...
Post by: Dean Erickson on June 19, 2009, 04:42:03 pm
Here is what I did for the mod. I put a nut on and compresed the spring. The nut is 5 MM thick. I have the clutch out of the car right now so I will report the results later.
(http://i637.photobucket.com/albums/uu91/DieselDean113/000_1502.jpg)
Post by: maxfax on June 19, 2009, 05:34:26 pm
Hmm...  I need more shims..   ;D
Post by: theman53 on June 19, 2009, 06:03:04 pm
Great idea guys. I was going to use a nut, but the only ones I had were too big and would bind. I know 6mm is about a 1/4" so 5mm should be in range. Even if it could go more you will definately notice a difference.
Post by: Dean Erickson on June 22, 2009, 03:50:08 pm
Here is what I found with the gov mod. the engine will rev a lot more and really puts out a black fog. Yes it has more power and is worth adding the 5 mm nut. It runs as normal untill you hold the pedal to the floor pulls harder in the upper rpms. I have no strange problems with how the engine runs. Here is a pic of the black mark I layed on the road.
(http://i637.photobucket.com/albums/uu91/DieselDean113/000_1504.jpg)
I now know I have a pos differential two black marks about 12 foot long I shifted into second gear and made one about 4 foot long. 8) I am going to look into a temp gage for the exhaust gas. I don't want to burn up my new engine.
Post by: Rabbit TD on June 22, 2009, 05:40:51 pm
That's a pretty little Rabbit, what year is it anyway?  Don't be too hard on that transmission too often, we have pretty weak pinion gears in these little creatures.  Check the BrokeVW site about transmission problems and their causes and our 020's are the weakest.  What are you using in the way of a clutch, must be a pretty good one and again I really like your Rabbit.  I'm a freak for them myself ;D
Post by: jwspin on June 22, 2009, 06:03:50 pm
from my experience and from the FAQ you should shim the intermediate spring so that its solid. it seems to help with throttle response. if you wanna raise your governed rpms then you shim the main spring. it looks like in the pic that you only shimmed the main spring?
-jared
Post by: theman53 on June 22, 2009, 07:06:26 pm
DO NOT SHIM THE INTERMEDIATE SPRING. Ask jimfoo, it makes it harder to drive. We need to clean the FAQ up so it says nothing about the intermediate spring at all. I think VW put it there for us to stumble on 30 years later.
What I found by shimming the main spring I could use LESS fuel screw and get the same or more power. To me it seemed that since it wasn't starting to shut it off at 2,000 something RPM and completely killing it at 4,400 RPM it didn't need as much of the big bag fuel screw :D.
Post by: jwspin on June 22, 2009, 07:11:57 pm
I havent done this for a few years but when you shim the main spring doesnt it push against the intermediate spring and basically shorten if not delete the spring travel anyway?
-jared
Post by: theman53 on June 22, 2009, 07:41:13 pm
(http://www.66rover.com/TDIswap/TDI%20Parts%20121307/slides/PICT1779.JPG)
In these you should see the top one is missing the idle spring, but you should see that there is a collar that doesn't let the main spring push on the intermediate. I wish it were the other way because my fingers would have liked it better that way.
Post by: Dean Erickson on June 23, 2009, 01:50:26 am
((((It has no effect on the intermediate spring)))) There is a c clip that seperate the two springs. The intermediate spring keeps the same pressure whan you mod the long main spring. It only compresses the long main spring. Don't mess with the intermediate spring!! It will make it harder to drive!!!!
