General Information => Troubleshooting => Topic started by: dave friday on June 09, 2009, 08:14:04 pm
Title: injection pump
Post by: dave friday on June 09, 2009, 08:14:04 pm
hi all,anyone know what causes the engine revs to go up and down [just above idle 1000/1200 rpm].
ta.
Title: Re: injection pump
Post by: rabbitman on June 09, 2009, 11:20:11 pm
Make sure all the IP mounting bolts are tight and that the brackets aren't cracked.
Post by: dave friday on June 10, 2009, 03:05:30 am
thanks for that,the fixings are all ok,it could be a mis-fire as the engine shakes a bit [i know of two other vans with the same problem!], my knowledge of injection pumps is a bit limited,could it be sucking air at those revs? [ i p drive shaft has a bit of radial play ].
Post by: rabbitman on June 10, 2009, 12:53:31 pm
Yes, air can cause missing.
A clear fuel hose feeding the IP would let you see if there's bubbles.
Post by: airhead on June 11, 2009, 09:13:30 am
Mine does this a little bit too when its warming up but seems to stop once it gets up to operating temperature. I dont worry about it.
Post by: Rabbit TD on June 11, 2009, 03:24:56 pm
Where in the world does a person get that clear hose at anyway.  Tractor Supply has some that says "Chemical Reistant" and I've been tempted to try it, what does anybody think about this?
Post by: BlastIt on June 12, 2009, 05:24:59 am
Auto parts store can get it for you. Some carry it in stock. Just tell them you need clear fuel line. They should
be able to hook you up.
