For Sale/Looking For => Parts for Sale/Wanted => Topic started by: ilikevwdiesel on May 27, 2009, 10:53:35 am
Thinking about boring a 1.6 TD and the pistons aren't cheap. Anyone know of a good source?
check out prothe. it seems that his pistons are great for stock performance.
yeah he's been hawking those pistons for some time now, anyone else have any feedback on Prothe and his TD pistons?
I've got some worn out ones (last oversize). They're a little egg-shaped but otherwise fine. I wouldn't really recommend them unless you just needed a replacement piston.
I have two sets of them in fresh bores. The first engine had 10,000 miles on it when I pulled it to install the second rebuild. The second rebuild currently has 6,500 miles on it. These are both N/A's.
I had no problems getting the rings to seat. However, I was quite meticulous with break-in....none of this mindless "drive it like you stole it thing." Both engines run very strong and I really put the coals to them (once seated)....as much as an N/A can.
I am currently running 10% hydraulic fluid as fuel in the second one and running it hard and no problems noted.
The company which builds these pistons is in Malaysia and they produce a LOT of industrial pistons for tractors, trucks, etc. THAT is why I felt reasonably confident to purchase these....and so far.....all is very well.
And, yes, I scored a pair of Kolbenschmidts for the Eco diesel....although I wonder if I really needed to.
Just my take for hard earned dollars.
So are those prothe supplied pistons you have?
Get Kolbenschmidts from Myke. $85 ea. is a great price.
