Engine Specific Info and Questions => IDI Engine => Topic started by: carrizog60 on April 12, 2009, 11:11:29 am
Title: help on converting wg can
Post by: carrizog60 on April 12, 2009, 11:11:29 am
hello
can someone help a bit by posting again the pics where the job of converting a VNT wastegate can to work with pressure?
i need to know how to open/close,convert to pressure,all the stuff to make it work.
i could try to do it without help but its the only one i have so i dont want to mess it up with trials...its a gt2052v unit if it matters.
thanks
Post by: carrizog60 on April 12, 2009, 12:00:34 pm
ok thanks.
and for the internals?
Post by: carrizog60 on April 13, 2009, 02:35:30 pm
up
Post by: Baixo on April 13, 2009, 04:56:38 pm
sorry for hi-jacking your thread....
but...I spent a evening in Aveiro recently in a trip to the Continente
Im jealous...haha
dont forget to post pics and videos of your VNT turbo'd TD
Post by: carrizog60 on April 14, 2009, 11:50:13 am
aveiro at night can be beautifull 8)
on to the topic:
one thing i cant figure out...
on rest position the vanes are in such  way that wont try to make boost right?
if i suck( :lol: )on the wg can the pin will go in and i supose it will start to try to make boost.
now,if i flip the internal wont the movement be on reverse?how would that work?
sorry but cant understand right... :oops:
Post by: hamradio on April 14, 2009, 01:30:35 pm
Instead of messing with flipping the internals of the vac actuator (actually, I did, and then got tired of messing with it), I took a t3 wastegate actuator (mine came from a volvo 740 or something), cut the shaft short, welded a piece of bolt in the thread of the original actuator to it, and tack welded it to the bracket that held the vac actuator.  It works great.
I'll grab some pics later tonight, as long as the turbo is out of the car.
Post by: carrizog60 on April 14, 2009, 02:03:24 pm
this is the turbo in question
(http://img89.imageshack.us/img89/2910/img0025a.jpg)
(http://img102.imageshack.us/img102/4470/img0024a.jpg)
(http://img89.imageshack.us/img89/4623/img0026as.jpg)
if i put the internal in the other way wont the shaft only try to move to the side that...it cant?because the shaft only moves to the can side.
i want to use the same setup as fspgtd and you libbypappa used but cant figure out how to make it and most pics on the forum are out... :cry:
Post by: carrizog60 on April 14, 2009, 03:04:35 pm
hum,i think i figure it out.
if i make a conection from the vane linkage to the throtle when i hit gas i will close the vanes and make boost.at idle they are open.
as soon as boost rises the pressurised air coming to the top of the wg can will make the WG can plunger go down and force vane linkage to open again.
the extra clearance needed is achieved by springs in the throtle connections.
if i am right till now what would control the boost level at witch the boost can will force the vanes to open?WG can spring?
and after the vanes being open will the boost stop climbing?
lets say,i want 1.5 bar from my setup.
will the can only move the vane control after hitting the 1.5 bar?or will be like stock pump governor and act sooner?
and will the boost stop increasing after 1.5 bar is reached(and vanes open) despite the increasing rpm and fuel ?
Post by: hamradio on April 14, 2009, 04:24:50 pm
Quote from: "libbybapa"
fspGTD (Jake) and I used very different setups.  Jake's setup used it with the internals flipped and an external wastegate mounted to the exhaust manifold.
Mine used the internals flipped and the accelerator actuation I mentioned earlier.  Mine does not have the actuator mounted to the turbo.
If you simply flip the internals and replace it onto the turbo you will have the vanes always closed unless boost is present.  That reduces efficiency by increasing back-pressure at idle and cruise and makes the transitions from cruise to acceleration "jumpy" but is a simpler method than the more complex linkages.  You have to decide what you want.
I'm running it vanes-normally-closed, and it works excellent.  I have them set a touch off of fully closed.  I don't think the transition from cruise-acceleration is jumpy at all; it's very drivable on the freeway, and overall very smooth and zippy in it's power.
Post by: carrizog60 on April 15, 2009, 11:54:45 pm
how would the vane return to rest position on part throttle driving?
Post by: carrizog60 on April 16, 2009, 11:59:56 pm
i will try to do my setup the way you(libbypappa) did.
i have made a "thing" and the problem its solved but unless the vane linkage as is own will to return to normal position i don't know how i will do it as the spring on the accelerator will pull the vane linkage even at part throttle or am i missing something?
Post by: carrizog60 on April 17, 2009, 12:08:55 am
(http://img410.imageshack.us/img410/1122/img0027a.jpg)
the vane linkage will attached to the metal plate with a adjustable screw.
the spring will be linked to a metal cable that will go to the accelerator.
the other adjustable screw with the disc on top will be were the WG screw will push.
is this right?
only missing the way to the vane return
Post by: arb on April 17, 2009, 05:41:52 am
really cool thread guys... I never would that thought of cutting open the can and screwing it back together.
keep us updated.
Post by: carrizog60 on April 19, 2009, 11:53:48 pm
any help on this?
Post by: carrizog60 on April 20, 2009, 11:54:51 pm
another great idea 8)
but the linkage from the WG can will not bend/jiggle when opening the vanes?
