Engine Specific Info and Questions => IDI Engine => Topic started by: Jettage1 on March 31, 2009, 05:06:46 am
Title: Pulsation?
Post by: Jettage1 on March 31, 2009, 05:06:46 am
So what would cause a pulsation felt in your forward motion under light/moderate acceleration?  It is not violent bucking at all, just a sort of forward / rearward motion, or I guess you'd say a rhythmic lack of consistency or smoothness in power delivery.  The car didn't always do this, so I know it's not normal.
The IP is bolted down tight, and I believe the clutch is fine.  Timing is around 1.00 and IP & injectors are new.  Is there some IP adjustment that would create or eliminate this sort of condition?  Maybe some sort of a fuel delivery issue?
Thanks guys.
Title: Pulsation?
Post by: Duster 5.9 on April 01, 2009, 01:27:06 pm
have you changed the filter lately? do you see any bubbles inline? anything leaking?
Title: Pulsation?
Post by: Jettage1 on April 01, 2009, 02:15:34 pm
Nothing's leaking, haven't seen bubbles, pump bolts are tight.  Will inspect motor mounts.
Haven't changed filter in awhile...  maybe that's a candidate.
Someone also suggested that excessive crankcase oil being burned (either from blowby or from the turbo) could lead to inconsistent behavior since the engine wouldn't be entirely controlled by the IP...
I disconnected the crankcase-to-intake return but no difference.  Since I do have some gray smoke under load I'm considering a turbo rebuild...
