Engine Specific Info and Questions => IDI Engine => Topic started by: hamradio on March 22, 2009, 05:43:39 pm
Title: Can someone outline aaz headgasket>1.6 mech?
Post by: hamradio on March 22, 2009, 05:43:39 pm
So, I cannot find a straightup DIY thread on this...just little bits and pieces here and there.
I'm wanting to put an aaz metal HG onto my 11mm 1.6 mechanical lifter engine.  Exactly which holes need to be plugged?
Thanks.
Devan
Post by: CODE4LS1 on March 23, 2009, 10:43:37 am
I am looking for the same info myself....sorry, son't mean to hijack.
Post by: zukgod1 on March 23, 2009, 12:44:45 pm
Search for MLS, there are several threads on the first page of teh search that has what you desire. Use the "Search for all terms".
Look for posts by me, zukgod1, 53 willys, libbypapa, saurkraut  I think as well.
There are others but you both need to do lots of reading then start a build thread so you can post pics and questions as you go.
Here is one for you to look at.
http://vwdiesel.net/phpBB/viewtopic.php?t=17296&highlight=mls
Post by: burn_your_money on March 24, 2009, 09:54:14 am
Please post all the good threads you find in the frequently asked thread in the FAQ. I'd like to add this mod to the list.
Post by: saurkraut on March 24, 2009, 02:39:14 pm
Get an extra oil fill cap gasket when you get the metal head gasket.  The VW AAZ metal head gasket has a hole for the extra front oil drain that all hydo lifter heads have.
Your head and block don't have this extra drain.  So you really don't plug anything.  You just fill part of the extra oil drain hole in the metal head gasket.
cut a piece from the brand new oil cap gasket to fit the hole in the metal head gasket where the extra front oil drain lines up with a coolant passage in you mechanical head and block.
You have extra difficulty points for trying to keep the 12mm holes in the gasket centered on your 11mm studs (I hope you have studs).
I don't know if the 11mm 1.6 blocks have the same problems with cracking the block due to the woefully short engagement length of the stock head bolts.  But it’s a biggy on the 1.5 engines.
If you already have studs, and a fiber gasket, you may want to waite till it blows of its own accord if it ever does.  I ran boucoup boost and fuel through my 1.6TD in my '79 with a fiber head gasket and studs.  Never had a problem.
