Engine Specific Info and Questions => IDI Engine => Topic started by: Garrett on March 16, 2009, 07:20:42 pm
Title: AAZ Waterpump Replacement
Post by: Garrett on March 16, 2009, 07:20:42 pm
I'm going to be replacing the waterpump and thermostat in my '97 AAZ Jetta tomorrow, and I'm just looking for any tips or tricks any of you guys/gals have. It looks like I will have to remove the alternator, A/C compressor and the tensioner bracket to gain access to the waterpump. The injection pump doesn't need to be moved right?
Thanks!
Post by: vixentd on March 16, 2009, 08:58:51 pm
Nope ip pump doesnt have to be removed.
1.  You will need a bent wrench to get the top to bolts, Unless you are only replacing the pump and not the entire housing.
2.  Hook up a vacuum cleaner to top rad house and turn on then slide thermostat in to hold in place, if you forget to install when pump is out.
Post by: Garrett on March 17, 2009, 03:51:58 am
Great, thanks dude!
