Engine Specific Info and Questions => IDI Engine => Topic started by: danwithagolf on March 12, 2009, 04:21:01 pm
Title: Trans q's
Post by: danwithagolf on March 12, 2009, 04:21:01 pm
ok so my buddy owns a 90 jetta turbo diesel not a eco we live in canada lol but anyways he was going on to the highway today and he said the clutch felt like it was slipping then it went BANG the hole trans blew apart! so he is wondering if any gasser trans will be ok? will the cv's still work? i know there are 2 diff size cv axles at the wreckers out here there are about 25 gasser jettas and golfs so it would be no prob getting one just no diesel ones any help would be awesome thanks dan
Title: Re: Trans q's
Post by: jtanguay on March 12, 2009, 04:35:19 pm
Quote from: "danwithagolf"
you just need to find a transmission with 90mm flanges.  the only thing with the gasser trans is the gearing.  it just plain sucks, but it'll work.
the corrado's WILL come with 100mm flanges, and the scirocco's will come in both flavours.  best to look for a TD transmission though.
Title: Trans q's
Post by: Dakotakid on March 12, 2009, 08:03:47 pm
Look for an ACN or ASF.
Avoid an AUG.
Go to the BrokeVW website and look at ratios.
If you get a trans with 100's....change them out for your 90's.
Take the time to put in all new seals.
Title: Trans q's
Post by: Rabbit on Roids on March 12, 2009, 08:16:24 pm
Quote from: "Dakotakid"
Avoid an AUG.
avoid an AUG? why do you say that? ive got one in my car and i love it. its got tall r&p and a .89 fifth gear. 2750 rpms at 60.
Title: Trans q's
Post by: jtanguay on March 12, 2009, 08:24:46 pm
Quote from: "Rabbit on Roids"
Avoid an AUG.
the ACN does about 2500 @ 60mph.  i can't wait to get my CTN rolling.  2150 rpm for 60mph. and maybe if i win the lottery i'll get the 0.658 to go 1900 rpm for 60 mph.  :lol: every bit helps!
Title: Trans q's
Post by: Dakotakid on March 12, 2009, 08:30:58 pm
I've got two of  these AUG's. The first is in a gas '85 Jetta (from a '92 Jetta with digifant originally). Yes, at 65 mph it is 3151 rpm or at 61 mph it is 3000 rpm. I have always seen those numbers as pretty high and b-u-z-z-y!!!!
In contrast, my beloved AGS and less beloved ACH's are looking at 2851 rpm at 65 mph and 3000 at 68 mph. On my long open roads, those numbers are quite a contrast. The gas car doesn't seem all that happy with it. My diesels would really hate those numbers.
Now, if I spent more time on winding roads or in the local mountains.....sure, I would be happy-er (at least in the gas car). Out on the open road.....I just don't care to hear my diesel engine THAT much!!!!
I actually worked on cleaning the 2nd AUG today. I am planning on putting the 0.89 in a car body (for the crusher) and I am going in with either a 0.71 or 0.75 from my other available transmissions. But, once again, this will be going into a gas car. There will be a noticeable gap between 4th and 5th....but, a gas engine won't mind very much.
This is just my take. :roll:
Title: Trans q's
Post by: Rabbit on Roids on March 12, 2009, 08:43:50 pm
yea, theres no such things as straight roads here. just windy mountain roads. so rippin through 5 close gears is way better. (and funner)
Title: Trans q's
Post by: Dakotakid on March 12, 2009, 09:05:45 pm
I should have a spare 5th gear for you as soon as I can get to the project (if you want the gear set).
Hey...better yet....you don't have a 0.75 set laying around that you don't want....do yeeez?????
Title: Trans q's
Post by: Rabbit on Roids on March 12, 2009, 10:08:19 pm
ive got a .71 laying around in my dreams somewhere..  :)
nope, only got access to an FN, an AGB (whatever came stock in a 16v GLI) and the aug in my car.
Title: Trans q's
Post by: danwithagolf on March 13, 2009, 10:57:16 am
he found a trans out of a 87 turbo diesel for 200 so he is going to pick it up can some one send me the link for the ratios? thanks dan
Title: Trans q's
Post by: jtanguay on March 13, 2009, 11:11:12 am
you'd be surprised, but a tall ratio turbo diesel transmission could be even better.  i remember with my old diesel i would just drive 4th gear through the hills.  5th gear - turbo didn't kick in until about 110km/h, so it was pretty much useless there.  damn that tranny was tall.  but still fun  :wink: i wish i had modded that thing  :lol:
Title: Trans q's
Post by: jtanguay on March 13, 2009, 11:15:12 am
it could be an AGS
3.94   3.45   1.94   1.29   0.91   0.75
*  R&P shown as both 67/17 (3.94) and 72/22 (3.27)
(the asterix is what shows in the excel spreadsheet i found.  that super tall r&p would be kick ass!!!)
Title: Trans q's
Post by: 1life2live on March 13, 2009, 11:16:28 am
im curious as to how many people have swapped 5th gear out before. I recently junked my 7a trans that has a .71 5th gear and bought an awy with .89 5th gear and would like to swap them. I tried last nite but was not able to figure out how to get the 5th gear out of my old trans. I tried to remove the bolt holding down the one gear set but could not remove it. is there a special way to remove it? Any info would be great i would love to have my .71 5th gear back
Title: Trans q's
Post by: Rabbit on Roids on March 13, 2009, 12:43:18 pm
im pretty sure they are a friction fit and need to be taken apart with a puller or a press of some sort.
Title: Trans q's
Post by: danwithagolf on March 13, 2009, 11:12:02 pm
so the one out of this 87 will be a 90mm for the cv's right my golf is and its a 87 but n/a so he hopes it will be good he wants the smokey beast back on the road!
Title: Trans q's
Post by: jtanguay on March 13, 2009, 11:49:51 pm
Quote from: "1life2live"
you just heat the gears and they should slide off.  using a puller could actually damage the gear.
Title: Trans q's
Post by: cyrus #1 on March 14, 2009, 10:43:05 am
For those of you wondering how to swap 5th gear:  8)
http://www.brokevw.com/5thswap.html
