Engine Specific Info and Questions => IDI Engine => Topic started by: UnderPSI on March 07, 2009, 04:02:32 pm
Title: 1.5 compression numbers
Post by: UnderPSI on March 07, 2009, 04:02:32 pm
What are good compression numbers for a 1.5. I currently have 375, 400, 500, and 350.
Post by: Rabbit TD on March 07, 2009, 07:16:37 pm
I had 2 80 Rabbits with the 1.5 engine in the early 90's which ll I did was hone and put in new rings and a valve job and they both had 500 in all cylinders.  they both had about 175,000 on them when I put the rings in.
Title: Re: 1.5 compression numbers
Post by: 88jetta350 on March 08, 2009, 05:21:48 am
Quote from: "UnderPSI"
Sounds like someone needs rings....
Really, uneven numbers like that suggest badly worn rings or bores, or valves.
You might want to start investigating that before something happens.
Post by: UnderPSI on March 08, 2009, 10:47:15 am
I recently did the head gasket, had the head pressure tested while it was off, came out ok. I'll have do new rings when i get the other head done I guess.
Post by: Deadeye on March 09, 2009, 12:04:42 am
I would check the wear at the piston skirts. You may want a new set of pistons..
I rerang a 1.5 once and It didn't last.. It turns out the pistons were worn about .012 smaller than stock.
