Engine Specific Info and Questions => IDI Engine => Topic started by: allsierra123 on March 03, 2009, 11:45:44 am
Ok how important really is the power steering? Could I leave the pump off? The stock T stat housing on the AAz interferes with the passenger side motor mount bracket. So I changed housings the new one interferes with mounting the PS pump. Any Ideas or suggestions would be helpful at this point Im about to ditch the pump. How badly would I miss It and would it cause any other problems with a van that previously had it?
Allsierra123,
About six months ago I changed my 1988 Vanagon with PS to manual. As Andrew suggested you want to locate a manual steering gear and switch them out. I ran mine for a while with the PS steering wheel and that was okay. Eventually I switched to a manual steering wheel and it does make a difference but not all that much.
I was concerned it might be like driving an old tractor but even my wife drives the Van without any problem. You will get used to the difference fairly quickly. Of course you only feel it when you are parking or turning from a stop. On the road their is no difference.
Good luck, Sam
Tucson, AZ
Dump the pump, get some exercise while parking.
Try the JX t-stat elbow first, 030 121 121 B, $12 from the dealer.
No interference with the motor mount or ps pump on the ones I've seen.
I hate to admit it but I've been driving around with a dead pump for a while & a new pump in box on my desk mocking me daily. Can't say I really miss it that much tho, just notice it parking.
good to know. Anyone know of an online dealer I can order from? We dont have one closer than 100 miles away.
Here, https://www.1stvwparts.com/partscat.html
there, http://www.worldimpex.com/parts/genuine-part-adapter_41627.html
shouldn't be hard to find it's on 98-01 Passat also.
I removed the PS from my 92' Caravan for my diesel conversion.... I'm sure it will be just fine. I had to adapt a 1988 new manual rack & pinion as they stopped making a manual version on that bigger vehicle.
I ran my syncro westy for 5 years with a 1,6td with the pump on and off.
I couldn't find a setup that pleased me, but a loaded syncro westy can be
a handfull off-road without the pump.
I agree though that it's not that bad. Yanking the pump or switching to a
manual rack is just fine.
Thanks for that, Andrew, I wasn't aware of that particular AAZ issue. :P
Nice work-around.
