General Information => Troubleshooting => Topic started by: burningchrome on February 16, 2009, 12:07:03 pm
Title: What's considered "cold"
Post by: burningchrome on February 16, 2009, 12:07:03 pm
I live in west coast BC. Normally the temp doesnt drop below 0 degrees Celsius but I have to pull my cod start lever all the way  out to get 86 Jetta TD started in the mornings. Is this normal?
Cheers,
Etienne
Post by: saurkraut on February 16, 2009, 01:37:55 pm
I pull the cold start out even in summer.  If the engine isn't at 190° F, its cold. :wink:
Post by: burningchrome on February 16, 2009, 02:12:36 pm
Thanks. Just what I needed to know.
Cheers,
Etienne
Post by: jiggs on February 18, 2009, 03:01:19 am
never pulled the lever...
in portugal, where i live and work in the winter temp´s go from -1ēc to 10ēc... warm engine is when it reaches 80ē.
cold? well, cold is ambient tēc...
you must be having timming probs or injection bad pressures...
even when the temp here reaches -5ēc I just let the resistance light go off... twice before the startup...
cheers
Post by: saurkraut on February 18, 2009, 04:14:18 pm
Why double glow?  All you have to do is glow it once and use the cold start knob as it was intended?
The cold start knob doesn't cost any thing, and double glowing for a couple degrees below frezing will shorten your glow plug life.
I usually don't have to double glow unless the temp is below -23° C
And I'll gladly use the cold start knob instead of advancing the beejeepers out of my timimg so its starts good cold, but rattles like a beer can full of pebbles when warmed up.  Thanks for the tip :roll:
Post by: jtanguay on February 18, 2009, 05:24:04 pm
theres actually a technique where you turn the engine over without glowplugs, for about 1-2 revolutions, then let it glow.  this is to superheat the diesel that is touching the glow plugs.  the motor should fire right up when following this method.  if not, your glowplugs are bad.
Post by: Smokey Eddy on February 18, 2009, 08:12:48 pm
I find mine starts up "better" with the lever out.
Are there any disadvantages to driving with the lever out?
Does it increase the amount of diesel or just advance timing.
Post by: truckinwagen on February 18, 2009, 08:19:11 pm
it advances timing at idle, so no real issue driving with it out
Post by: zukgod1 on February 18, 2009, 09:22:12 pm
Quote from: "jtanguay"
I stumbled across this method. Mine starts up much easier if I hit the starter for a sec them off and back on to let the GP's get hot then fire it up.
Its still pretty cold here in Utah and my car had been sitting for 2 weeks not plugged in, I fired it up yesterday after work just because I needed some diesel in my blood  :twisted: , fired right up.
No cold start lever.
Post by: saurkraut on February 19, 2009, 07:33:07 am
I can start mine too without the lever.  It just runs a little smoother at cold idle with it out.  The bearings in the engine and the turbo will be happier if they are allowed to gently warm up rather than getting a quick goose of the go pedal to get them all firing.  And unburned or partially burned fuel out the exhaust port or on the cylinder walls and then into the oil pan is not a good thing in either case.
It make sense to me to have a modified advance for the brief period of engine warm up, rather than run more total advance all the time just to avoid the arduous task of pulling the cold start lever.
Post by: carrizog60 on February 21, 2009, 12:33:28 am
according to vw you have to pull the advancing knob only after the engine is cranked. :arrow:
Post by: 8v-of-fury on February 21, 2009, 09:50:02 am
Quote from: "carrizog60"
You mean like after its already running? doesn't that defeat the purpose? :P
Its called a cold "START" lever for a reason lol not a cold run lever. but hey, i guess vw knows best :) i find with mine set at 1.00 and with the lever out it starts and idles right after starting ALOT smoother then without using it.
Post by: burningchrome on February 21, 2009, 07:05:45 pm
So I tried JT's trick to coat the glow plugs with diesel do
ing a couple of pre-cranks and it was a no go. When I have some time I'm going to remove the bus and check each plug individually. Is there some tips to removing the bus and glowplugs behind the IP,if thats what I have to do. It looks like it could be a frustrating job.
Cheers,
Etienne
Post by: rabbitman on March 11, 2009, 05:49:20 pm
Mine cranks faster with the cold start in. With the knob out the earlier injection makes it harder to crank. I pull it out as soon as it fires up.
Post by: 8v-of-fury on March 11, 2009, 06:41:52 pm
i think someone on here not to long ago actually figured out that it advances it by like roughly 27 degrees or something. That is a ton! Why would you want to double glow? why not not save your time and just pull a small lever out ? :P
I would use mine all the time, it just makes it easier on the engine, and its better for the environment. i think?
Post by: Jettage1 on March 11, 2009, 08:00:38 pm
Quote from: "8v-of-fury"
I think that's about right...I had the dial indicator in my IP set to zero with the lever "in".  I pulled it out just for kicks and the gauge moved to the upper 20's, IIRC.  27-30 sounds about right.
Post by: rabbitman on March 14, 2009, 11:29:42 am
Those numbers aren't degrees, that means .270inches of plunger lift, I think.
The 85-92 bentley actually says IIRC, 5 degrees advance and the 77-84 bentley says 2 or 2.5 degrees.
Post by: rabbitman on March 14, 2009, 11:35:25 am
Those numbers aren't degrees, that means .270inches of plunger lift, I think. Hopefully someone else chimes in.
The 85-92 bentley actually says IIRC, 5 degrees of advance and the 77-84 bentley says 2 or 2.5 degrees.
Post by: 8v-of-fury on March 14, 2009, 12:52:31 pm
ohh.. ha ha that makes sense.. so .270" equals out to roughly 3 degrees.. that's pretty cool my badd lol
Amazing what 3-4 degrees will do eh??
Post by: theman53 on March 14, 2009, 04:27:48 pm
Not really. I read my manual and it said that if its cold you want to turn the key to the cranking position. As it starts cranking then you pull the CS lever out. Instead of the way I usually do it which is pull the CS lever and start cranking.
Post by: burn_your_money on March 14, 2009, 05:06:27 pm
I pull mine out, cycle the plugs once and then start it.
I know that the mk1 manuals say to start the car with the lever in, and then pull it out once it is running, not sure about mk2s+.
It's a bad idea to leave your cold start pulled out all the time. The timing piston will smash into the cold start mechanism and create metal filings which can wear out the advance bore. It's best to just leave it out for as short of a time as necessary. If you are driving and not idling, it doesn't matter because the piston has already moved out of range of the timing advance.
The later mk2 pumps have the fast idle and you can push them in a bit and have no extra advance but still have the fast idle.
Post by: rabbitman on March 15, 2009, 12:20:37 pm
If you read hagars "saga", he says max advance is 24 degrees @ 5000 rpm.
Title: Re: What's considered "cold"
Post by: 8v-of-fury on November 24, 2009, 05:56:40 pm
So i just wanted to dig this thread up again... as i will be trying desperately to get my diesel going before the snow flies!! and drive it for this winter!!
I am going to be replacing GP's, Timing belt and tensioner, and pimping it a la Vince style while im in there.. What will be the best timing to set the pump too? I know many set n/a pumps to 1.00mm but i want to know what will be best for optimal starting and running. Maybe set it to 0.95mm so that way when i use the cold start it advances it to 1.00mm.. or even set it to 1.00mm and then it will advance to 1.05mm.. what should I do?
Also I can see now why it is said to pull it out after cranking, as too much advance causes the fuel to ignite at the wrong time working against the engine, causing slow and sluggishly battery killing starts! So keep it retarded for starting and then pull it out when it catches to advance it after the starter and battery are out of play. Sounds like a good method i will try. Also I will try the crank for a second, then hit the glows and see how that works on a separate run. Then together! lol should make it start like a TDI :) lol
I feel confident that even on some pretty cold starts this thing will be a monster winter mobile!
SO! Whats the OPTIMAL winter timing value? I have the tools and can change it in the spring if I like. Would like to go for performance whilst maintaining start-ability.
thanks a lot guys.
Post by: wolf_walker on November 24, 2009, 06:35:11 pm
There isn't a one size fits all answer for these motors(and injectors, and pumps, etc) after a few decades.
I can tell you my hyd head NA motor with a 107A pump timed at .98 or so with new duraterms fires instantly into
the mid 30's so far, cold start does nothing perceptable, never use it.  Experience says given good battery
it'll fire up fine down to way colder than we ever see here.  It rattles above idle cold, badly, so I let it warm up five minutes in the morning, no noise when warm.  Go figure.
What I'd prefer, is less base timing, more dynamic advance, and to use the cold start handle to get it where it is now
when cold for starting.  That's going to take some experimenting though.
Post by: 8v-of-fury on November 24, 2009, 06:50:17 pm
the mid 30's so far, cold start does nothing perceptible, never use it.  Experience says given good battery
I see, that is a very good answer. I was just wondering what would be the ideal spot though you know? like around factory timing? or a little advanced from that? How much is too much advanced? where does it start to be more bad than good? just a few curious thoughts i had.. lmao.
What do some of you have yours set at and what temps is your car starting in?
Post by: wolf_walker on November 24, 2009, 10:00:09 pm
These little motors are pretty vocal about timing in my experience, sometimes you can't hear it in the damn car they are so rattley and loud in general, but there is a marked difference between clattery diesel happyness and clattery diesel unhappyness.
To my knowledge and modest experience as much advance as you can get away with and things not sound bad, is good.
NA anyway, I'd want an EGT to fiddle with a turbo car too much, all that melting of metal and such.
