Engine Specific Info and Questions => IDI Engine => Topic started by: carrizog60 on December 26, 2008, 01:55:49 pm
i know i have to do the exhaust and redo the oil lines but what else?
i don't think it would stay in a position were the outlet point in the right position...
do i need to adjust the geometry or other things?
and what about doing the vacuum»pressure conversion on the can?
the pics are all dead...can anyone bring them again?
thanks
do these come off newer merecedes?
no, this one was from a audi 2.5 tdi.
it as the exhaust flange in rectangular shape,more easy to fit on gtd
The FAQ forum has a sticky quick guide that has links to most/all of the VNT threads.
Andrew
the ones i need have the pics dead...
i want to see how to adapt the can
Like this (http://www.kotinet.com/matti.farm/Audi/Moottori/114-1492_img.jpg)
sorry if i spelled wrong...
the turbo already as is can, but i need to convert her to work with pressure instead of vacuum.
there were some pics around but they are offline...
mjf,you already had this previously right?
how was the ride with this turbo?
Open the can, flip the spring to other side and put it together. Klik (http://www.kotinet.com/matti.farm/Audi/Moottori/114-1500_img.jpg)
I liked it very much, IŽd recommend it :) Spools faster than stock T3 and is good to ~170-180hp in IDI.
wwwooowww!! thats it, now I realize that yuou are right carrizo...
sorry for the discussion in the forum the other day... :oops:
what discussion?these thing still amaze me as time go by...
mjf, thanks! :wink:
mjf, thanks! :wink:
nitrox post, :roll: clube golf pt... remember?
i know, but that wasn't a discussion :wink:
pics show me pics!!!
:D
I am really ansious to see it run.
So are you running that turbo without a mechanical connection to the throttle to yank on the vanes initially during acceleration? (like Libbybapa, Tintin & others...) From your post it sounds like you are using the vanes & the reversed actuator sort of like a wastgate to open and control boost with boost pressure with the vanes closed at idle. If so then isn't there a chance of huge pressure surges & if the line pops off no "safe mode" for the turbo where the vanes default to open & no boost?
