Engine Specific Info and Questions => IDI Engine => Topic started by: Cody on December 24, 2008, 08:28:28 am
Title: Mystery Pump
Post by: Cody on December 24, 2008, 08:28:28 am
Whilst installing one of Gary Lee's Tire Carriers onto my 1991 Factory Diesel Syncro (Air snorkel on LHD driver's side) we found a mystery air pump tucked into the corner of the engine compartment that tee's into the snorkel upstream of the air filter and pumps (Gary was suggeting it was a pump) air into a tube that disappears down under the engine.
Bentley doesn't seem to have any reference to it.
Anybody know what it does?
Thanks,
Cody
Title: Mystery Pump
Post by: VW_Commuter on December 24, 2008, 08:49:08 am
Pics?
Title: Mystery Pump
Post by: arb on December 24, 2008, 09:16:42 am
Does it plumb into the vac system ?
Title: Mystery Pump
Post by: dave friday on December 24, 2008, 12:16:15 pm
Turbo cooling fan,its switched on when the water temperature gets to 104or107degc ,with the auxillary water pump.
Title: It's a turbo cooling fan
Post by: Cody on December 25, 2008, 04:28:24 pm
Yep it's the turbo Cooling fan.  Although some say  it kicks in when the temperature gets high and others that it kicks in when the engine stops.
Not sure which at this point.
Can supply some pics if someone can tell me how to insert them into teh message.
Cheers,
Cody
Title: Re: It's a turbo cooling fan
Post by: Turbinepowered on December 25, 2008, 08:12:38 pm
Quote from: "Cody"
Step one is to get them hosted somewhere on the internet. I use www.photobucket.com, it's free, you get a good-sized chunk of storage, and they help you out.
Step two is to get the url where the picture is stored. When you hit "reply," one of the options on your screen under the post subject box is "IMG."
If you push the IMG button, it inserts a little bit of BBcode, that looks a bit like this: [IMG].
Paste the URL next in that row, then hit the IMG button again. It'll put another bit of code in the post, that looks something like this: [/IMG*].
Note: The [/IMG*] tag above has the * added in to break the tag. If the * were left out, the boards would try to read all the characters between the opening tag and the closing tag as a URL, and throw errors.
Once you have your URL nestled between its opening and closing tags, hit post, and voila! You have a picture in a post.
Be careful of how big of pictures you post; most forums I'm part of have a limit of ~800px high and 500px wide, to keep from stretching the internet window out of whack.
Help?
Title: Mystery Pump
Post by: the caveman on December 26, 2008, 06:32:48 am
Isn't it the factory turbo diesel air seperator for the air intake. I have seen pics and it does look like a pump. I beleive it works as a cyclone to make sure water doesn't get in.
Title: Mystery Pump
Post by: dave friday on December 26, 2008, 07:12:15 am
As i said earlier its the turbo cooling fan [i have one on my van!] it is switched on by a switch in the cylinder head water system [on mine at 107degc] it doesnt mater if the engine is on or off!!.
