General Information => Troubleshooting => Topic started by: AudiVWguy on November 25, 2008, 04:54:16 pm
I've put up with this for a while, but thought now was the time to have a go at it. Any suggestions on where to start first? Anybody BTDT ?
Thanks,
-JB
Could it be your relay?
MK1s don't come with intermittent. You need to add it in. If you look at your fuse panel you should see a large metal jumper piece connecting 2 sockets. Remove this and put in a wiper relay from a mk2 and you should have intermittent.
You're good Tyler....very very good. :wink:
Here's my obscure "blast from the past" Rabbit memory... there may also be a plastic wedge on the wiper control stalk that's preventing it from going down into the "intermittent" position.
Ohh I think you are correct as well. Good catch
Nah... just tripped me up once working on my shiny red 1979 Rabbit back in the day. Ah... the memories... :cry:
http://www.4crawler.com/Diesel/CheapTricks/index.shtml#WiperUpgrade
The LX pick-up had intermittent wipers, I swapped out the relay, IT WORKS!!
Thanks Guys! :D
-JB
oooOOOOooooh, sweet! I'm gonna try that one.
I had that problem for a while untill I got a used relay, then intermittent and high/low worked. But the auto stop only works sometimes :roll: every now and then I have to pop the relay out and smack it on something. 8)
