General Information => Troubleshooting => Topic started by: mtnbob on October 28, 2008, 09:07:01 pm
Since I've had my Golf, I've been adding a little brake fluid every once in awhile. Today brake pedal went to the floor and found out I was out of brake fluid. Where is the most likely place it is leaking from? I filled reservoir back up and it is working OK and I know I need to fix it, but I don't see any leaks. :shock: Suggestions??
If you're losing brake fluid and you don't see any leaks then the usual suspect is the master cylinder... leaking into the vacuum booster.
If you pull the vacuum booster hose you may be able to smell it/ see it... otherwise you could pull the M/C and see if the pushrod is wet.
Probably in the rear brake (one side or the other) from the wheel cylinder that sits at the top of the backing plate. Eventually, it will come out the bottom where the drum and backing plate almost meet.
The shoes can pick up the fluid and render the rear brake "gone."
Gently use a propane torch to remove the little screws that hold it on when you replace it. They tend to freeze in place very well.
Ty for the suggestions Looks like this is my weekend project. I'm guessing M/C since the car sat for awhile before I started working on it.. We will see :?
X2.
I see this all the time. You'll want to replace the booster too. It's sure to be full of brake fluid.
last year i noticed one side near the rear tire was always 'wet'... then my brakes were getting pretty bad... to the point that they weren't working anymore. sure enough it was the rear cylinder. changed that out and poof! working brakes!!! be careful with the brake fluid as it will eat most anything it touches.
i hope its not your MC. :(
ok if I need a M/C and vacuum booster what kind is best? are they expensive?
When I looked up M/C's they were pretty cheap.
I literally just had the same kind of probelm. Mine turned out to be the rear pressure regulator literally broke. I lost a little at a time. It was slow at first then got to leaking pretty good.
http://www.vwdiesel.net/phpBB/viewtopic.php?t=16607
Check that out to consider that too. I got a pick n pull 10$ part vs new 130$.
Ty Possum I will be under the car in a few days, and that will be the first thing I look at. BTW where is it? :shock:
its where all the brake lines meet at the back... can't miss it!
put some cardboard under the rear of the car and fill with brake fluid, then start car and give a few pedal depresses... then leave overnight and you should find some wet spots.
booster
http://www.partsamerica.com/ProductDetail.aspx?MfrCode=A1C&MfrPartNumber=535730
master cylinder
http://www.partsamerica.com/ProductDetail.aspx?MfrCode=A1C&MfrPartNumber=112206&PartType=230&PTSet=A
dunno if the links will work
Yea like JT said its in the rear on the driver side. Mine was a thing that looked like this:
http://www.germanautoparts.com/Volkswagen/Rabbit/Brake/235/2
Going through a junk yard I noticed different ones on newer vehicles. Same basic idea of all the lines going in then out.
i like these guys' prices!
http://www.germanautoparts.com/Volkswagen/Jetta/Brake/235/2
too bad its in the states... why did the dollar have to drop so fast!!! :evil:
What's the verdict, Bob????
The suspense is a-killin' me!!!!
Augh i hear ya :cry: :cry:
im broke now because of it and my order from prothe.
man i really www.wishtherewascheapparts.com (http://www.apoke.com/) !!!! :lol:
I knew what that would do but I had to see for myself! :P
Thanks dickhead.
Thanks dickhead.
np :wink: :lol: spread the love
Sorry had to keep adding fluid until tomorrow or Monday. I've been swamped :shock:
just remember that the brake fluid is going somewhere... and it will eat right through pavement :shock: :lol: although not as bad as gasoline
I think Vince is right. Sounds like futures in brake fluid may be on the up-slope!!!!
buy now!!! :lol:
Thanks dickhead.
I second that!!
