For Sale/Looking For => Parts for Sale/Wanted => Topic started by: blkboostedtruck on October 12, 2008, 12:21:14 pm
HEY GUY'S I'M GONNA HAVE YOU GUYS CALL SEAN YOUR SELVES!
CONTACT INFO IS ON PAGE 3 I WILL PUT IT IN THIS FIRST THREAD
EXPLANATION IS ON PAGE 3! THANKS Duane
if anyone is interested in new nozzels the more we buy the less they are!
261 72 available
265 70 available
293 12 available
314 12 available
Blkboostedtruck= 12nozzels
SR Heer = 8 nozzels
Foxracer1= 8 nozzels
familydiesel= 8 nozzels
cyrus#1 =8 nozzels
19bucks for individual nozzels
if i have an order for more then 20 it drops to 18bucks per nozzel
and if more then 40 in a order it drops more per nozzel
so if anyone interested i'd like to place an order this week!
those listed above are what in stock now!
well let me know!
thanks Duane
Sean 1-919-828-5221 say your in Duane's group buy in wisconsin!
(those are the magic words)
Hessian American Imports
717 A chappell Dr.
Raleigh, NC. 27606
[email protected]
Blkboostedtruck's contact info.
K. Duane Keaton
4275 S. 35th. st.
Greenfield, Wi. 53221
414-840-1395 cell
Duane,
I will be wanting to get a set of nozzles for my 1.6GTD engine - what do you recommend and how much?
Also will be wanting to get a set of nozzles for AAZ 1.9 TD dual rate injectors - what do you recommend for these and how much?
What do you charge to pop test and adjust these to say 165 BAR and are the dual rate injectors any more difficult to set up than the single rate ones?
Thanks
Duane,
Thanks
261for GTD motor will work great! price determines on how many buy during the group buy so right now 19bucks per nozzel i charge 75bucks to rebulld 4 injectors!
it's alot of work! if your pump is stock then 155bar is fine for pop pressure
i cannot do dual spring injectors as of yet! you would have to send those off to giles or a injection shop! special equipment to do those settings on dual spring injectors!
Duane
261 work fine in AAZ injectors
bump
I would be interested in some GTD probably at least 8.
Hi Duane,
If I understand right, would the 261's work for my 85 1.6 td? If so, I would take 4. I might be persuaded to take 8 if it would make a price difference.
Oh, let me know if you are including me in the count, and when you will need the money etc.
Greg
What are the options? What 3 are they? GTD, AAZ, and factory?
i'm waiting for info that tells what the #'s mean they have to do with the spray pattern as soon as i get it i'll post it!
and i'll start a list in my first thread on who's buying what!
so go ahead and state how many and what size you want ?
shipping should be 5bucks extra to your total cost
i'll P.M. everyone later for thier shipping info!
Duane
This is a good deal and I've already bought 4 but I couldn't wait for the GB to happen, I need injectors now.
Better pony up if you think there is even a slight chance you are going to rebuild your injectors within the next 2 years. You can always sell the tips down the road if you don't use them.
I'd like larger ones but just having new ones will be good. Let me know what you can get when you find out.
I'm just waiting on the table. I'm interested. I have mercedez nozzles from this site
http://www.veg-injection-service.com/store/index.php?main_page=product_info&cPath=6_8&products_id=29
I have had good results with these so i figured i'd post the link in a related post.
Are the nozzles you're getting similar Duane?
Sweet deal if this goes through. I wonder if you could do the same with glow plugs or entire injectors? :roll: :wink:
i've seen that site and what scares me is that i cannot see part # nor a bosch logo on the injectors pictured in that link! typical sign of Chinese knock offs!
i have Dan's (zukgod1) injectors here for a repop job and you guys would need to ask him where he got them and how long he used them?
because the nozzels are junk! leak bad! will not hold and have the worse spray pattern i've ever seen! i've threw away old bosch nozzels that had hundreds of thousands of miles that were better then these!
these nozzels i get come from monarch witch is from germany !
the guy i deal with goes to germany alot! his wife has family there!
also this is the same guy i did the injector shim group buy with!
anybody is welcome to his contact info ! he's a very nice guy and has not bull***ted me at all! and he will stand by his product and i can vouch for that!
I have high standards and anything i deal with has to meet my expectations because i'm rough on my equipment and it's gotta last!
and i been into VW's since 1986 when i bought my first VW ("66 sqareback type 3) witch i still have to this day! who elso do you know that has kept their first car over 30years? now thats devotion!
Duane
I added some 314 to the list i forgot to add at first there is 12 available currently!
me personally i'm getting some used 308 from him i wish he had them new!
but beggers can't be choosy
Duane
x2. I will be checking back regularly. Have you heard anything more about what the part #'s represent?
Cody
i've started a list for a count so we can get an idea where were at!
let me know if i have the correct amounts by your names?
as soon as i get the info then once you guys know exactly the one's you want ! and i'll add the part #'s to your names! anybody else want on the list?
nows the time!
thanks Duane
How do the numbers relate to the nozzle?
I'm interested in a nozzle group buy. However, I have no idea what the nozzle numbers mean either.
It's for my 1.6TD. I'm not looking for a performance gain really. Maybe a bit?
Matt
I've been trying to research this further to no avail. All I seem to be able to find is the "DNO SD" series part numbers. Kerma has a 193 nozzle listed for N/A applications 80-92, and a 308 nozzle listed as GTD replacements. :?
I will need 4 but will be using WVO in a 1.6TD, So you tell me which will work best.
Herb
hi, ya put me down for four of the 261 if those are the GTD's. Thanks.
Herb
In my experience the 293 or the 265 work better then the stock nozzle, if it were my car I would lean towards the 293.
I am highly interested in the group buy and would get 9x 293's and 4x 265's
I got mine installed, they idle much smoother.
They sure don't deliver the same amount of fuel as my Big Ass injectors, I had to turn the fuel screw almost 1 full turn in to get the idle back where it was :shock: .
They seem to work great in all instances.
My EGT's are higher but that's due to the higher pop offs I had Duane set them to. Old ones were 139 and new ones are 165 so I need to advance my timing a tad again.
Over all I really like them so far, mileage is about the same. Filled up this morning and got 43.6 mpg average.
Buy em up guys..!!
hi there
can you get tdi nozzles too?
Buy em up guys..!!
Dan whats the biggest badest set that will work well on set-up's like ours???
I'm kinda worried about these china merc tips im running after hearing how F'ed yours were.... :shock:
I got them merc nozzles to....the infamous ones.
Put me in for 4 im game. just need to figure out what size for my setup.
Turned my na pump up yester day and built 23 lbs...accident i swear. :oops: ..cant belive the head stayed on. no studs...just strechy bolts.
Need to get some good injectors and run this baby right.
i bury my 20 psi gauge quite often... metal HG though on a 1.6 8) no head studs either! the head bolts can actually hold quite a bit... its just the gasket material...
ok guys this is the unoffical nozzel break down! i have not heard from my supplyer yet bet this is what i know! and for those that ask about what size for veg oil stock size is fine!
193 for 1.5 and early 1.6
261 for merc. used in vw's as upgrade works great
265 for merc. used in vw's as upgrade works great also had something to do with emissions on merc. but i don't have the info!
273 commonly used on 1.6 TD and other's
293 these are i'm pretty sure are the GTD's nozzel's
308 these i've seen offered for 1.9's
314 these i don't know? but prolly work good on a 1.9!
if anybody has something to share or see something i missed in nozzel size chime in please!
thanks Duane
For those of you that know my build, I talked with the vendor and we decided on the 261's for me. Sounded like the best option for economy and power. I have about 500 miles on them so far and they are great, ran with a VR the other morning. He won but not by much, I was pushing 30psi and running 1350 egts @ 102 mph when I backed out, speeding tickets are bad enough add wreckless driving or exhibition of speed and the price goes up. Fun.
I want some BFI's!!!!!!
witch ones are those?? :D
Im with this guy :!:
Ill take four 293's
try them 314 they should be big enough!
or 308 but Sean is out of them!
hey you mail my stickers yet bud? because i'm a weinner :roll:
Duane
Duane
Ok add me to the list...I want 4-314 nozzles..
So no 308's???? new or used???
Duane I will ship your stickers in the morning....I have been working so late on my week ends that I missed the post office before they closed...But I will ship them out in the AM I promise 8)
hey guys i think i'm gonna change this around? what i'll do is just have you guys that want nozels contact Sean your selves ! well it just makes sence ? back when i did the shim group buy i had to separate and bag the shims! with these they can be shipped by him direct and all payments can go right to him and it would cost less! well less shipping involved! those of you that want my rebuild service you can instruct Sean to send them to me! he has my address so not to worry! Dan (zukgod1) has all ready tested this method for you! i will call sean tomorrow and let him know his phone will be ringing off the hook! you guys that have questions about his product he's the guy to ask!
best to call! Sean 1-919-828-5221 mention your in Duane's group buy from wisconsin! (those are the magic words)
717 A chappell Dr.
Raleigh, NC. 27606
[email protected]
thanks Duane
I'm in for 4 - I have a 1.6 ecoboost, looking for best economy / power. Should I be getting the 261 or the 273 ?
I'll have you rebuild my injectors - that includes the calibration ? I have 8 used injectors with less than 200K miles on them. Would the extra set have any value to you ?
-dave
-dave
my rebuild cost is totally separate from the nozzel buy!
i have plenty of old injectors around here i don't need any more! thanks any how!
what ever size you decide with it's your choice
Duane
Duane does AWESOME work guys.
Do NOT hesitate to have him do your injectors.
Good guy, good work, good turn around.
Sounds great, but which nozzle should I use ?
i don't know witch to tell ya? you got that big old heavy van!
Duane
Thanks Duane. I will contact Sean before the end of the week. If I need you to rebuild my injectors I will shoot you a pm. :D
Duane
Yes, it is heavier, but has a Coefficient of drag: 0.39 and the MK2 has 0.36, so the load at speed isn't that much more...
hey you guys that call Sean and have your nozzels shipped to me please include your GTD user name to Sean so i know who's who!!
Thanks Duane
Hi Duane, what's your address for me to send you my injectors to rebuild / calibrate when you get the nozzles ?
my contact info is in the first opening thread!
thanks Duane
