Engine Specific Info and Questions => IDI Engine => Topic started by: allsierra123 on October 01, 2008, 03:22:55 pm
Not sure what the difference is visually does anyone have any pics? Here is a pic of mine.
(http://i95.photobucket.com/albums/l122/allsierraappliance/91%20vanagon/024.jpg)
Which is it?
I think it's just plunger size and cam plate in the pump doesn't have quite so steep a vertex on an evo pump. Less lift = less fuel = eco?
Is there is a visible difference?
depends on witch your refering too? 1.6 or 1.9
Duane
LDA PUMP :D from a 1.6 base and a peugoet lda.
(http://i249.photobucket.com/albums/gg206/2253benjamin/powder008.jpg)
My 1.9 doesnt have that thing sticking out on the top middle.
Thats the manual shutoff(kill switch) for the auto peugoet.vw didnt offer that on the 1.6.
AAZ eco pump... no LDA:
(http://i197.photobucket.com/albums/aa85/vwaldon/AAZ_AC_idle.jpg)
you have a passat by chance? there is a pic. around here of a passat echo pump around here on the forum!
Duane
i meant that one above! boy your fast vince?
It may have come out of a passat but It looks different than that one. Im going to try to snap a pic of it tomorrow in the daylight and post it.
Do I need to have someone host photo's to post them here?
a photo bucket account then you can post your own pics.
Duane
Ok here ya go .
Well you certainly have an 1.9l AAZ-style pump with a LDA.
Can you make out any of the numbers on the side ?? In particular, if you can get teh Bosch number or the number that starts with VE we can figure out the plunger size.
Where would I find it. There is a small plate on the side that has a bunch of numbers on it. But I dont see one that starts with VE.
That is a true TD 1.9 pump. As Andrew said, you have a "joke" pin in that there is only a very small difference between on and off boost fueling. It is not a eco diesel though
Take the top number, it will start with 0 460 xyx xxx The y is the plunger size. 8 = 8mm, 9 = 9mm 0 = 10 mm etc. Yours should be a 9
That pump should have T30s, not flat screws holding the top cover on
Is the pin upgradeable, Well the whole pump for that matter?
If you want an all out pump, with all the tricks, send it to Giles.
If you want some more go on the cheap, check the FAQ for the "make your 1.9 a faster car"
Good to know so I need to locate the top end of a 1.6 TD pump.
