Engine Specific Info and Questions => IDI Engine => Topic started by: Smokey Eddy on September 29, 2008, 10:08:14 pm
Title: Smokey Delight - symptoms = diagnosis
Post by: Smokey Eddy on September 29, 2008, 10:08:14 pm
A good example of terrible compression, cracks deep between valves and shot rings.
Here is my car, it is very broken.
(http://i49.photobucket.com/albums/f279/edmcclung/SSPX0165.jpg)
When i start it this happens.
(http://i49.photobucket.com/albums/f279/edmcclung/SSPX0158.jpg)(http://i49.photobucket.com/albums/f279/edmcclung/SSPX0159.jpg)
(http://i49.photobucket.com/albums/f279/edmcclung/SSPX0160.jpg)(http://i49.photobucket.com/albums/f279/edmcclung/SSPX0161.jpg)
(http://i49.photobucket.com/albums/f279/edmcclung/SSPX0162.jpg)
When it's hot it gets better
(http://i49.photobucket.com/albums/f279/edmcclung/SSPX0163.jpg)(http://i49.photobucket.com/albums/f279/edmcclung/SSPX0164.jpg)
I thought those pictures were worth a laugh.
I'm building a new one. New head - bored block new pistons and a properly timed IP
Post by: smutts on September 30, 2008, 12:50:24 pm
Smoke smells of diesel? Tried a set of glow plugs? Smoke smells of burning lubricant? Hmm, not so good. :roll:
Post by: Smokey Eddy on September 30, 2008, 03:18:28 pm
New gps. New gp system. Even when its hot when i start it, it does that.
It's just messed up beyond all repair.
Post by: fatmobile on September 30, 2008, 10:27:34 pm
Do you have a clear fuel line betweeen the filter and injection pump?
 If you do;... see any air moving when you first start it?
Post by: Smokey Eddy on October 01, 2008, 12:04:55 am
yeah i did. Big longg bubbles sometimes. so i got a new filter, cut the ends of the lines and put it back together snug and filled it up with diesel.
Still get the bubbles.
Post by: clbanman on October 01, 2008, 02:52:12 am
http://www.vwdiesel.net/phpBB/viewtopic.php?t=10588
White smoke can be unburned fuel, especially if its only on startup.  We have had trucks with sticking injectors that did this.  As mentioned, if this is the cause, you will get a strong diesel smell.  Does get rid of mosquitos though.
Post by: Smokey Eddy on October 01, 2008, 12:14:29 pm
Hahahhaha thats awesome!
Post by: morefuel on October 01, 2008, 07:12:24 pm
i normally run a some tranny fluid in my diesel to help clean things out  old wise tail my dad told me hes and ex vw mechanic and  knows his diesels and  IP's pretty good
but id say that yours is past that past hope
Post by: Smokey Eddy on October 01, 2008, 07:13:48 pm
Hahaha i know! but good tip!!!
Post by: rabbitman on October 01, 2008, 11:33:10 pm
Andrew, why do you say the bubbles are causing the smoke? :?
Post by: Smokey Eddy on October 02, 2008, 12:56:08 am
Could be the bubbles but i don't know what to do about that anymore? I replaced everything and it still happens... much less but there are still some sometimes.
that doesn't make any sense to me.
I think it's also:
-two knocking injectors
-very poor IP timing
-very very low compression
Post by: arb on October 02, 2008, 07:58:59 am
I'd look at every junction from the filter to the tank with an eye for anyplace with seepage - it could show where the air is coming from. If none, look in the tank. The air needs to be stopped.
Post by: Smokey Eddy on October 02, 2008, 12:30:16 pm
Ahhhhhhhh
Thanks a lot guys. Okay...
This is what i replaced
-fuel filter
-black lines between injectors
-the main seals on the IP including the shaft one (the one that has to be pressed on)
This is what i did... probably not the brightest ideas
-removed the water sperator (my spliced/joined line is very likely the issue i realize now thanks to your kind and wise words)
-i cut the ends of all the fuel lines and put them back on and replaced hose clamps that skipped under slight load
I'm going to make something better to join those two lines. Thanks guys!
Post by: arb on October 02, 2008, 12:59:03 pm
True, but if it was sucking air, lots of bubble as he said, I would expect when it sits long enough that the pressure equalized there should be some wetting around the leak.
