Engine Specific Info and Questions => IDI Engine => Topic started by: TTH on September 15, 2008, 07:31:36 am
Title: 1993 Passat TD glow plug problem.
Post by: TTH on September 15, 2008, 07:31:36 am
Hey all,
I tried a search for glow plug problems relating to the B3 Passat, and searched some of the repair manual pdf files on the web, but couldn't find what I need.
The glow plugs quit working after I swapped a used cylinder head on.  The light on the dash will not light up, and I don't get voltage to the glow plugs when I key on.  Under the dash, I checked relay location # 12 (bottom right) for continuity.  Position 87 has continuity to the glow plugs, position 30 has 12 volts all the time.  I would imagine that position 85 supplies switched ground to the relay from ???.  The relay itself works when grounded (I pulled it to test).
It looks like the problem is that for whatever reason, I am not getting position 85 grounded.  I could really use a tutorial from someone explaining how the remainder of the circuit works, and what to test.  Reading some previous posts, it looks like there should be a glow plug timer (location?) and a coolant temperature switch that provides an input to the timer.
Any help appreciated.  Thanks!
Post by: zukgod1 on September 15, 2008, 08:14:54 am
Did you reuse the coolent outlet/sensors from your old head or was there one already on the replacment head?
Post by: TTH on September 15, 2008, 09:37:41 am
Quote from: "zukgod1"
I believe I used the one that was on the replacement head.  Did they have different sensors for different years or chassis?
Post by: zukgod1 on September 15, 2008, 11:05:48 am
you could just have a bad sensor,
Try swapping your old one on and see if that takes care of it.
