Engine Specific Info and Questions => IDI Engine => Topic started by: James8485 on August 28, 2008, 06:44:49 pm
well im kinda narrowing my hangin rpms to my nozzles as they have 325000 on them im guessin and i burn like no oil between changes well not enough to have my rpms hang on me, pumps good(rebult ) and motor rebuilt with 25000 on it so far
the only thing i didnt do was the nozzles
will 1.6L TD GTD nozzles fit directly into mine as i dont want to have them shipped and take out mine and have a mess to deal with
is there any jimmying to get em to fit......i am lookin for alittle more power and heard these are the way to go please need info ASAP as i want to purchase
thanks
full injectors and high pressure lines are bolt on.
the nozzles fit your injectors, but AAZ's have two springs and as far as I know only a few people can set both pressures, Giles is one of them.
well i know the stck aaz injectors are a duel spring but i was under the impression that the 1.6 TD GTD injector are a single spring.....
it will be alittle louder but more power is what im looking for
please let me know about that duel spring thing as i thought they (1.6 GTD nozzles) had one
1.6 injectors are shorter, so you would have to bend your lines to make them work, or get new lines as well.
Research I did told me that the GTD nozzle is the same one that's in the AAZ. different injector body though. Just get a rebuilt set of AAZ injectors.
X2
I installed the GTD nozzles in my 1.9 AAZ injectors and it runs very well. My injectors that were in the car were not running well so I took them out and rebuilt them with the gtd nozzles. I know that there is two breaking points on these injectors but I only set the first breaking point and not the second since I don't have the proper tools to do the second. I put everything back together and put them in the car and it runs way better. I have better pickup and a bit better mileage.
this may sound so stupid but my injectors/nozzles are old and prob in need or replacing
do i buy a set on new/rebuilt nozzles or injectors>>
can someone clarifie this,,,,,,,,,,,like using the GTD am i using the injectors and nozzles or what
so lost!
A search for "gtd AND nozzles" yielded:
http://www.vwdiesel.net/phpBB/viewtopic.php?t=15588&highlight=gtd+nozzles
so lost!
i think you can only get the GTD nozzles and then you need to either replace them yourself, or get it done by a shop which also has the tools to properly calibrate them. Giles can do it :wink:
http://www.kermatdi.com/servlet/Detail?category=VW+IDI+nozzles+%28Not+TDI%29&no=21&searchpath=159916
This is what's in my car, as far as I know it's AAZ original equipment, and GTD original equipment. The nozzles are the same, but the injector bodies are different between the 2.
