For Sale/Looking For => Parts for Sale/Wanted => Topic started by: Riverfurm on August 11, 2008, 02:39:17 pm
Looking for a block 1.6 turbo solid lifter (don't need head) block code MF.
Around Philadelphia Pa. Trenton NJ area (within 100 miles).
Wish full thinking??????? :roll:
Thanks Furman
Got one coming from Bryn from Ok. Thanks for all your help :P :P
are MF's all hydro's? all i seen are hydro's even the one's i have in the garage are hydro's!
Duane
http://www.thesamba.com/vw/classifieds/detail.php?id=632697
I had a solid lifter MF code 1985 Jetta turbo diesel, they do exist (or maybe that is existed...)
Greg
did they have 11mm or 12mm heat bolts/studs?
Greg
yes now that i thought about it your right! i do remember and they may be hard to find because of such a short time being made from the factory!
Duane
Greg
12mm as far as i know!
Duane
The motor in my '91 Jetta is an MF code solid lifter block. And, yes, they do have 12mm head bolts (or studs if you go that route).
I see you guys don't live close to me and don't have a block for sale.
Thats what I'm looking for. Any help? Any leads?
all td's were 12mm...
I have one I'm trying to sell,... but am in Iowa.
Thanks Fatmobile..... Shipping is a killer. :( But if I can't find one I might need yours. How much are you asking?
Please don't hijack my post. I am looking for a block. If you don't have one don't leave a message on this post. PM each other if you what to talk about head bolt size or MF code engines.
Thanks.... I'm a little frustrated because the vendor (Parts Place)who said three weeks to put together a short block is going on six, and I need this car running.
Do you just need a block or do you need a shortblock?
blocks are light and cheap to ship through fedex ground.
Just letting you know.
FYI - fatmobile might part it out.
I'd possibly interested in the other stuff if you wanted to go in on it...
I have a block at the machinist getting ready to be bored for 1.7 pistons,... they told me it is cracked so it looks like I'll be needing this block.
Could sell you a complete engine that I broke a timing belt on last year, had about 420 pounds of compression until I broke the belt. I'm a long way away though. It's about 3 1/2 hours to buffalo NY. Engine has a sticker on the side that says it was a VW rebuild, so who knows if it's been bored already. Make me an offer and come and help pull it out of a '92 Jetta...........
Got another one in the trailer already out, head off. Head is probably beyond using, but it ran when pulled. Engine had over 500,000 km and less than 275 lbs on all cylinders, guess why it got pulled! Definetly needs to be bored.
Got a third one that was bored and ran great, but had a precup come loose and destroyed one hole..........
Got one from Bryn in Ok.
Good. Hate to see someone stuck for parts!
The Short block I got from Bryn is in very good shape. It had 2 over pistons and a stock crank with standard bearings. I was going to hone it up and re-ring, replace the bearings. But with the luck I have been having I sent the block, pistons and crank to the machine shop to be checked out.
