Engine Specific Info and Questions => TDI Engine -General Info => Topic started by: oldskool rich on August 06, 2008, 11:03:04 am
i want to flow as much air as possible, 35psi, no/little lag, must be super reliable and wait for it.... cheap
whats best value for money?
i think VNT is out of the question for reliability and drivability, looking at ball bearing turbos such as garrett T28, anyone tried these? anyone know of a good turbo? my T3 its pure toss :(
why do you say that? the only damaged vnts I've seen were the one that were being run way past they're specs, or oil starvation/coke from shutting down immediately after a hard run.
from those demands, you are probably interested in a compound setup, two "cheap" turbos instead of an ultra special one.
yea i'd personally go with a nice big VNT. as mentioned in previous posts, the main reason the VNT's are dying is because they are directly matched to the engines output, and not over-engineered. just get a nice big one and off you go.
if you have the money to spend on a ball bearing turbo, go that route. it will spool as fast if not faster than the VNT's. $$$$$ though!
