General Information => General => Topic started by: subsonic on July 24, 2008, 09:39:06 am
Just got off th phone with the dealer. He confirmed that the crank bolt part number for a 1.6TD was the same part number for the crank bolt on early 1.9TDI's. Will post the part number when I go pick it up on monday. Might make finding 1.6 crank bolts a bit easier now.
jim
Sorry for the delay.
Part number # N-905-771-01
Cost from dealer 2.70
It also has the 12 point head vs the 6 point.
Is this the bolt that holds on the timing gear?
yes. bolt that holds timing sprocket to crank shaft nose.
