Engine Specific Info and Questions => IDI Engine => Topic started by: chrisrandle1 on July 20, 2008, 04:53:47 am
Title: Cummings VE Pump to a VW VE Pump???
Post by: chrisrandle1 on July 20, 2008, 04:53:47 am
I was wondering if anyone knew if there would be any gains, or if it was even possible to convert a cummings ve pump to a vw pump.  It seems to me that if you were to change the rotor and head, it might work.
Just an idea.
What do you guys think?
-Chris
Post by: dillenger1 on July 20, 2008, 04:57:06 am
the governor spring is different.The shaft is larger to.I believe the lda will switch over though as long as you remove the gov assedmbly.
Post by: chrisrandle1 on July 20, 2008, 05:00:30 am
Possible Gains?
Post by: chrisrandle1 on July 20, 2008, 12:11:23 pm
I also noticed that they were a bit more expensive...I guess I will forget that idea.
Thanks for the replys
-Chris
Post by: fatmobile on July 20, 2008, 09:29:08 pm
the control collar lever assembly has the wrong offset
 Will this keep me from sticking the 12mm head on the VW pump body?
