General Information => General => Topic started by: dieseldubber on July 05, 2008, 06:37:56 pm
Title: which injectors and glowplugs to run?
Post by: dieseldubber on July 05, 2008, 06:37:56 pm
Hey guys I am going to do my glow plugs and install new injectors. I figure they are the original ones (the injectors) and instaling new ones will help reduce the black death smoke(clean air filter,fuel not turned up yet and I use stanadyne lubricity/cetane boost in every tank). I would like to mod the car to perform like a stock GTI and already have the 3'' turbo back exhaust. I read that Dave at passenger can tune the cars so they don't smoke much. Which injectors will match my goal of having a peppier daily driver, do I just use stock ones? Thanks.
Post by: jtanguay on July 05, 2008, 10:12:25 pm
well the GTD ones that smog sells are probably good for an extra 5 hp or so.  at least thats what my butt dyno tells me  8)  :lol:
Giles is the man for serious pump tuning though.  and if your pump has never been touched, it might be time for a rebuild anyway  :wink:
Post by: burn_your_money on July 06, 2008, 05:00:59 pm
get Bosch Duraterms for glowplugs.
You are getting complete injectors right? not just the nozzles?
Post by: fatmobile on July 06, 2008, 11:04:53 pm
What number are the GTD inserts?
 293?
Post by: Vincent Waldon on July 07, 2008, 09:24:28 am
I've seen "GTD nozzles" listed as SD274 and also SD276... I believe SD293s are the generic 1.6 replacement nozzle most jobbers are carrying these days ??
