General Information => Troubleshooting => Topic started by: jimfoo on June 18, 2008, 11:04:15 am
I found a little white nylon roller looking thing by my wifes Beetle. I'm not sure if it's from it or not. It has about a 1/4" hole, .375" thick, .68" diameter which has rounded sides. Is there anything similar on a Beetle? It seems hard to shift into 1st when cold, but fine other than that.
where did you find it?
inside, outside, in the oil pan?
On the ground. I'm thinking it might not be from the car since 2 of the dimensions seem more like inch than metric, but I have never seen it before.
can you post a pic ?
Its the roller that you put toilet paper on! :shock:
The more I look at it, the more I think I have seen it somewhere other than the car, so for now, consider the case closed. Thanks anyway!
