Engine Specific Info and Questions => TDI Engine -General Info => Topic started by: RabbitGTDguy on June 07, 2008, 11:55:40 am
Check this out...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=6019&viewitem=&item=320259656128&_trksid=p3907.m29
Pretty interesting...
(http://carad.ebayimg.com/i12/06/a/000/78/9a/18d3_4.JPG)
Lombordini also of course has variants of other aircooled diesels in two cylinder and 3 cylinder form.... close to 50hp and just over 100nm of torque.
http://www.lombardinigroup.it/common/binary_reader.php?idtbl=2&id_file=84
http://www.lombardinigroup.it/common/binary_reader.php?idtbl=2&id_file=37
Consider the possibilities for the ole' aircooleds out there...without the need to go to a watercooled engine... :)
Not screamers of course...but with fuel the way it is...
Though...a nice little turbo could help things out as well :)
just thought it was an interesting read. The Lambordini site is really interesting too.
Joe
my grandfather has a diesel Lombardini on his tractor, watercooled, 3 cylinder, IP is an inline one.
when you push the throttle too much it spews liquid diesel from the exaust ;) (and lifts the front of the 2tonne beast in the process )
not particularly good emissions wise.
a good long runner intake might do that thing justice too. port n polish etc 8)
there are def. refinements that could be made...we're not thinking too much on the emissions here...could be fun. The idea is interesting enough..
Waiting to see what he responds to regarding my questions
Joe
My uncle has a generator with one of their engines in it. He seems to think it works great. Just a 5kw generator for a backup in case there is no sun or wind for a week.
He uses it to weld for the most part or load equalize his battery bank as required.
lol...funny to think it is running a beetle around!
Joe
Just heard from the guy who is in charge of the auction of the car...
His response to my question on mpg...
According to the consignor it get around 40 to 45MPG.
Thanks,
Dale
Auction City
eBay Sales
650-367-7788
Not too bad for that little motor!
Joe
40-45 mpg on a 2 cyl engine??? that seems a bit low.. surely a 1.6TD installed in there should net at LEAST 40 mpg and be wayyyy faster. maybe they're just driving it way past its efficiency range? screaming on the highway? :lol:
well...if you think about it. They just "installed" the diesel engine. There was no attention paid to the tranny, etc. So, with that aircooled 4speed tranny...she would be screaming. I'm suprised of the mileage they are getting given that fact...
1.6 TD would be nice...but its even more cool in this aspect that they were able to retain the character of the car and not have to add the additional weight, etc. that the watercooled counterpart would involve. If I ever thought of such a thing, aircooled is def. the route I'd go. Converted aircooleds to watercooleds are "odd" to say the least in my book.
Look at the bay bus...still produced in Brazil....but now as a watercooled...just doesn't seem right.
Joe
:lol: slow internet day....double post... :lol:
see below
Rethinking/regearing the tranny would make a huge difference in this case.
Joe
I'm still hoping Jake Raby is serious about his aircooled VW boxer diesel engine idea.
With MPG figures, since that engine is only 25-ish hp, I'm sure they probably have to drive it pedal to the metal all the time just to get it to go anywhere- can't be good for efficiency. :P
def. not the most efficient route...but cool that it was done none the less.
JAKE is AWESOME. I'm still waiting on the final production run of his TYPIV style header system for the late model bus. I keep putting off buying another CRAP system from EMPI or (the once good parts called EMPI) because of it. I've talked with him many times...
Hadn't heard about his diesel ideas... DI would def. be easier than IDI on the motors we have...hmm...
Joe
thing is you only need HP for quick acceleration. low hp is all you need to keep moving at speed.
i've been thinking of getting a few large capacitors to store some 'juice' for those quick acceleration moments. wondering how good it would be considering it might take anywhere from 10 seconds to 1 minute to charge the capacitors??? best thing is that capacitors can hold their charge for a few hours to a few days :)
could replace the alternator with a generator, that way it can serve to recharge the system, and provide those 'quick' spurts of energy.
either way you do it, it would be an awesome hybrid! 80 mpg 8)
interesting...
I've heard similar discussions about converting current cars to more of a "hybrid" status via the use of water, building capacitors, etc. I haven't even looked into it any farther...but someone at work was talking about it today. Sounded interested....and def wasn't "hydrogen fuel cells", its a hydrogen generator.
http://www.youtube.com/watch?v=fwKFZTAhCns
http://www.youtube.com/watch?v=09f_OiZq-4Y&feature=related
www.runyourcarwithwater.org
Check it out...was interesting...
Joe
makes me wonder if it would be possible to create enough hydrogen to run the car while it drives...? seems almost like perpetual motion, but it seems as though it could work.
using salt in the water is a must though, and any other catalyst that will help break the molecular bond...
It is indeed really interesting and I've been reading ALOT of stuff on it tonight and viewing vids, etc. It seems as if it is the real deal and there are several "stages" of it. Some can make a "hybrid" situation, and just assist and reduce the amount of gasoline used....others, more advanced, larger hydrogen generators can power THE ENTIRE CAR!!! On water...
Reports on different setups range from 38mpg or so...all the way up to some examples running on later Honda Accords that are netting close to 60mpg. Usually 20-30% increase of efficiency vs. gasoline alone.
Interesting...
Now... the debate being that you have to put more energy and "get less out" it seems is the hot topic with HHO. This should almost be another thread.
Can you imagine the possibilities?
Digging deeper...one of the pioneers for this tech. and making it work was supposedly killed by the gov. after visiting the pentagon...was considered for patent and was going to be involved in the original STAR WARS program of the 80's, was going to build prototype engines to power tanks, etc. and then mysteriously was poisoned. I didn't dig to deep into this area, or the legitimacy of those claims, etc. (supposedly he was offered millions by Arab countries, big league oil, etc. to sell his ideas to them) but was more focused on the DIY'er possibilies and feasibility of this. It looks real and is feasible.
Interesting stuff...
Joe
