Engine Specific Info and Questions => IDI Engine => Topic started by: sandman126 on May 19, 2008, 03:16:59 pm
Title: AAZ turbo diesel into MK2 jetta
Post by: sandman126 on May 19, 2008, 03:16:59 pm
i was wondering if the engine mounts were the same or if i have to do some fabrication to make it fit right in the engine bay? and what all i have to do to the gas lines and tank so i can convert it to diesel? Im doing complete mechanical(no ecu) so could i get away with adjusting the mechanical fuel pump, getting an intercooler, and maybe adjusting the wastegate to get a little bit more power?
Also what should i do about a gauge cluster, use my gasser or get diesel tach?
Any suggestions and/or info would be very helpful!
Thanx :)
Post by: burn_your_money on May 19, 2008, 07:23:26 pm
It does bolt in, and if you do a search and take the time to sift through all the threads that come up you'll see that both of these conversions have been done a few times.
Also, the FAQ section has an excellent link to making your car faster.
If you have any problems finding the links, let us know.
Post by: sandman126 on May 19, 2008, 08:22:02 pm
thanks much, i have already found some info, im just starting in the turbo diesel area and loving it, i have liked VW's for quite a while tho
Thanx Again :D
