General Information => General => Topic started by: KTZed on April 28, 2008, 08:35:57 am
Title: Goodbye @#^%* Exh. C-clamps!
Post by: KTZed on April 28, 2008, 08:35:57 am
My weekend handywork...sorry for the crappy cell pic.
(http://i229.photobucket.com/albums/ee94/ktzed/downpipe.jpg)
Post by: zukgod1 on April 28, 2008, 09:27:50 am
Sexyness!!
Build 2?
Post by: spencebm on April 28, 2008, 11:54:00 am
that might outflow the stock dp, but im not sure...
Post by: Dirtrag2 on April 28, 2008, 12:32:36 pm
looks like 2 1/2", yes?
nice work ina any case  :lol:
Post by: Op-Ivy on April 28, 2008, 12:33:15 pm
Nice! This summer I'll be doing something like this too. The "toilet bowl" part with the seal leaks and I can't get it to stop :(
Where did you source the parts and how are you going to connect it to the rest of the exhaust?
EDIT: PS, nice welds!
Post by: KTZed on April 28, 2008, 01:05:22 pm
Yes its 2.5" mandrel. I bought 2 "U" bends but only used one and a bit. I could have got away with just 1 "J" bend.
Its hard to see in the pic but there is a V-band flange welded to the end of the flex pipe and the clamp is on the table (freezer full of moose lol) as well.
I bought everything from http://stores.ebay.ca/Exhaust-Direct-Performance
Good prices and Jim was great to deal with there.
Edit: I bougth the V-band from http://siliconeintakes.com
Post by: geetus on May 05, 2008, 07:12:50 pm
Nice looking DP. I am building one too and I used yours for inspiration. Hoping to get mine welded up sometime this week.
Cheers.
Post by: zukgod1 on May 05, 2008, 09:36:27 pm
where did you get the flange?
Post by: Vincent Waldon on May 05, 2008, 10:52:23 pm
...and the other question I wanted to ask.... how long is the braided section ??
Thanks for sharing your great project !
Post by: KTZed on May 05, 2008, 11:27:31 pm
I used the 2.5 x 6 (http://search.stores.ebay.ca/Exhaust-Direct-Performance_flex-2-5_W0QQfcdZ2QQfciZQ2d1QQfclZ3QQfromZR10QQfsnZExhaustQ20DirectQ20PerformanceQQfsooZ1QQfsopZ1QQsaselZ224633224QQsatitleZflexQ202Q2e5QQsofpZ0) although I probably could have fit the 8". I figure longer is better as it will put less stress on the turbo/exh manifold.
Thanks for all the kind remarks. It was my first downpipe build and im rather happy with it. I also just got rid of my sidepipe exhaust as I was hitting it on everything and I half assed the hangers so it rattled. Full 2.5 mandrel turbo to bumper now with no muffler. I'll see if I can get a pic of that too.
Post by: zukgod1 on May 06, 2008, 06:56:54 am
Quote from: "zukgod1"
Umm???
Post by: KTZed on May 06, 2008, 08:36:16 am
The turbo flange? I made it out of some 3/8 steel plate. Just clamped the old downpipe to it to use as a drill jig.
Post by: zukgod1 on May 06, 2008, 09:21:52 am
That sounds good to me..
I found a place that sells pre cut flanges for a reasonable price.
I think it was like $15 shipped for one..
I don't have a torch so it's tough for me to cut them out.
The last DP I made I just used a square piece of 3/8 that was WAY to big but it worked..
Were you able to keep the flange from warping while you welded it ok?
As in did it dish it out? I wasn't paying enough attention and mine was a tad warped when done, was able to just use a file to fix it  but would have been nice if I would have payed attention and not warped it.
Post by: Vincent Waldon on May 06, 2008, 09:57:01 am
Do tell... I'm torchless as well ??!!!
Post by: KTZed on May 06, 2008, 10:20:40 am
Who needs a torch when you have an angle grinder with a cutting disk  8)
I used a 2.5" hole saw to cut the centre hole (which is centred in the 4 mounting holes btw) and the exh. pipe being 2.5 OD fit perfectly inside. I welded the flange on the inside and outside to try to prevent warping and then flattened the surface with a flapper disk on the grinder.
Post by: zukgod1 on May 06, 2008, 12:20:36 pm
Quote from: "Vincent Waldon"
http://turboaddictionparts.com/catalog/index.php?main_page=product_info&cPath=15_19&products_id=71
http://stores.channeladvisor.com/verociousmotorsports/Flanges%20and%20Gaskets/Turbo/
http://cgi.ebay.com/ebaymotors/3-downpipe-flange-GT-T3-T4-4-Bolt-Turbo-Discharge-CNC_W0QQcmdZViewItemQQ_trksidZp1742Q2em153Q2el1262QQcategoryZ33742QQihZ001QQitemZ110244158742
http://cgi.ebay.com/ebaymotors/T3-T4-Turbo-2-5-exhaust-downpipe-weld-flange-4-bolt_W0QQcmdZViewItemQQ_trksidZp1742Q2em153Q2el1262QQcategoryZ33742QQihZ001QQitemZ110249425047
Some of these may not work, I've not measured to see which one I was just board for a sec and did a quick search.
Post by: Vincent Waldon on May 06, 2008, 01:19:03 pm
Thanks muchly !
