General Information => Troubleshooting => Topic started by: subsonic on April 25, 2008, 03:00:03 pm
I am installing a new alternator in my 85 golf na. It comes equipped with a/c, but does not have ps. I purchased a new alt for a non a/c setup as I was intending to remove the a/c from my car. I need to get the car running though, so I have replaced the non a/c pulley on the alt with a with a/c pulley. Belts line up. Alt bolts into place. The original alt bracket that attaches to the top of the alt and is connected to the block near the timing cover no longer fits. It appears to be too short to connect to the new alt. It has a slight bend in it, and two holes. It does not have the notches in it.
Do a/c and non a/c alternators have different mounting holes on them?
Why the hell does this not fit?
I need to get this damn car on the road :x
you got the bracket?
Yes AC and NON AC have different mounting points on the alternator. The tab on the casing has 2 holes. AC uses the upper, non ac uses the lower hole. You can use a bolt and nut or tap the hole.
I had to fabricate an extension to connect it to the alt. It was about 4-6 inches long. I bolted a extension to the end of the top bracket, tilted the alt up until it was in a good spot, marked the end of the extension, and drilled a hole. Bolted them together, one in the last hole on the oem bracket, one in the fist of the two holes on the alt. Big pain in the ass, but it works.
Alt is still in place no movment, belt is loose as hell though. So loose in fact, my alt light came on half way to work. I do not think I am going to have enough movment in the tensioner pulley to fully tighten it again. This is getting to be a pain in the ass. How freaking hard is it to just swap the alt and have it work. Now I need to drive it home, 70 miles with no alt belt, at night with the lights on in a damn rain storm. :x
Well that doesnt sound fun :shock:
well at least the alt. pully i sent you was right! well was it?
Duane
The pulley lines right up with the other pulley on the a/c compressor, so that looks good. The belt does ride low in the pulley, but it is in the same spots as the wear marks that were on the pulley. I have retensioned the belt twice so for. Once after a few min or running, 2nd time after about a 10 min drive. That should have accounted for stretch.
It was so loose when I got to work that it was not even spining the alt. I am going to try and borrow some tools and see if I can get anymore adjustment from the tensioner pulley. If not, I may have to resort to doing the one light trick I read about on here, and hope it helps enough to limp home.
I have no idea why it is getting so loose. :(
Maybe you are overtightening the belt which will cause it to fail faster.
Nope, did not over tighten.
I made it home last night just on the battery. Have it plugged in to a charger this morning.
This morning I adjusted the belt tensioner all the way out. The belt is marginaly tighter. If I grab the alt pulley I can spin it with my hand if I twist slightly hard,even with the belt on. No way it should be that loose with the adjuster all the way out. I have like a good 3-4 inches of delfection in the middle when I push on the belt.
I will try and take some pictures so you see, but it all looks solid. The only thing I can think of to do is use the adjuster on the a/c compressor to lower it away from the alternator, increasing the tension between the two, but that will cause the other belt to be loose.
This response is probably so dumb
it's beyond comprehension.
Is it possible that your supplier sold
you the wrong size belt?
As you know, there are different lengths
for the alternator with, without a/c, power
steering.
Perhaps the belt is simply the wrong
size and too long for your application.
I can check. What I have on it is :
Kelly/Springfield
13275
13/32in x 25.5in 38 degree
Just called and checked, they said that is the correct part number, and correct length.
Why not just go to the local auto parts store and get a shorter belt?
Thought about it on the drive in to work. The parts guy told me this is the correct belt that goes over the water pump/alt /ac. this is just ac and alt. hmmm.
I believe you said you were taking the
a/c out of your car.
I have a 1991 Jetta which originally had
a/c (now removed).
I have the original alternator & bracket
still installed.
The V-Belt I have is from the crank pulley
to water pump/alternator.
The belt is 13mmX960mm (1/2"X37-7/8")
Part #9375 from Carquest.
I don't know if this will help you out.
Perhaps the 1985 Golf se -up is different.
OK, here are some photo's.
This is the bracket that goes on top of the alt. this is the one that was too short.
(http://i239.photobucket.com/albums/ff120/subsonic44/alternator/DSCN0375.jpg)
Here is a shot of the alt with the mounting holes.
(http://i239.photobucket.com/albums/ff120/subsonic44/alternator/DSCN0376.jpg)
Here you can see where it is not long enough to reach the mounting holes.
(http://i239.photobucket.com/albums/ff120/subsonic44/alternator/DSCN0377.jpg)
Here is a shot of the bracket extension I made, attached to the alt.
(http://i239.photobucket.com/albums/ff120/subsonic44/alternator/DSCN0380.jpg)
Everything put together.
(http://i239.photobucket.com/albums/ff120/subsonic44/alternator/DSCN0381.jpg)
Shot down the pulley. It looks like it may be off a bit. Between the metal alt fan and the alt there are two spacers. One is a large flat looking washer type deal, probably 3" across. Then there is a stepped metal piece that has some flats on it so you can hold it while you tension the nut inside the pulley. Do I need the 3" washer type deal? If I remove it, the pulley will come in a bit closer and might help. Thoughts?
(http://i239.photobucket.com/albums/ff120/subsonic44/alternator/DSCN0382.jpg)
Like I said. Adjuster is all the way out. Belt is very very loose.
Every parts store I call tells me they have the correct belt, compressor over waterpump to the alt. As you can see, mine does not go over the waterpump. Does anyone have the correct belt number?
If I just opt for a shorter belt, any idea how much less I should go for on the first try? I was thinking about 3" or more.
So I went and bought belt 3" or so shorter today. Hope it helps. Had to pull over on the way home last night and plug in the battery charger behind a convienence store. Car was almost out of juice completley.
Made a mistake in my previous post. old belt was 27" and change, not 25".
Will get it on in the morning asap.
you got too many washers behind the Alt. fan ! the fan blades should just clear the housing! as far as belt don't go by what a part place tells you what the correct belt size is! the correct belt is the one that fits and that will vary depending on pully size, size of alternator? belt # is also a size # for example 1580 was a half inch too big get the next size smaller 1575! an understanding of the belt numbering would of made thing easier for you! pics. help a lot!
i know that pully is correct for your application you just got it spaced wrong!
but learning curve ! looks like you have it under controll?
thanks Duane
Yep, got it figured out now. Life gets better though. The belt was flapping so much it rubbed a hole through the plastic timing cover. I was half way home tonight, just got off the highway, sitting at a red light. Light turns green, creeping in 1st about 4-5 mph because its a down hill part of the road, push in the clutch to shift to second----THUNK! car dies.
Did you guess timing belt? You win a prize! I think the alt belt must have been rubbing up against the timing belt. Had to push it into a store parking lot and call the wife at 10pm to come and get me, one hour from home. Oh yeah, load all three sleeping kids in the minivan as well. FUN fun fun, more than I can stand.
I hope its not all ***ed up. I just had this head rebuild a few years ago.
Well, I am going to have a stiff drink and go to bed. In the morning I will need to figure out how I am going to get my car home, and spend another weekend desperatly trying to get a car running so I can get to work. This would be why, my wife politely reminds me, that we should buy new cars, that run.
Life is grand.
you sure it was timing belt? you sure you did not run out of battery?
well good luck especially all you went through! new car is not the answer! i have to disagree with your wife! you can rebuild your golf 4 times for what you pay for a new car!
Duane
Yeah, it's the timing belt :( . I popped the top latches on the cover and could open it a few inches. I reached in with my finger and could move the belt. It is still on the pulley, but has zero tension. I could lift it off the pulley with my finger.
Think it is possible to go with a new belt and re-time, or is it time to pull the head?
When you take the valve cover off you should be able to tell.
Since it didn't die and go clunk,clunk,clunk,clunk,clunk,clunk,clunk,clunk,clunk,clunk, clunk,clunk,clunk,clunk,clunk,clunk,clunk,clunk it probably stopped right away without hammering too many parts.
I`d try a new timing belt, turn it by hand and feel for compression on all 4 cylinders.
That`s pretty lame man :(
Never done this before. I guess I am going to pull the valve cover and look for damage to the cam or lifters. Anything else?
Pull the timing belt cover off, toss the old belt. Do I then pull the cap on the tranny and turn the engine over by hand until I see the TDC mark? Won't I hit valves by turning it? I am kind of worried about getting everything TDC and lined up before I get the new belt on.
I just got my timing kit from germany, so once I figure it out, I should be able to use it.
This forum is great, but having someone standing next to you who knows what they are doing sure is a big bonus. Anyone live near the Maine /Mass / NH line on the seacoast who would care to lend a helping hand? It is sitting right off Rt-101, about 15 or 20 min up from I-95 in Epping NH.
removing or loosening the cam caps will definitely work. Make sure to do it in the proper sequence so you don't snap the camshaft.
I had the car towed to a good shop. I just did not have time to work on it with the 12 hour days. They got to it yesterday. 1 and 4 both have a valve that is not working correctly. New belt etc. turned over with no contact, hoped the compression would help get them going again but no luck. All my damn money I am saving for my franken is being eaten up by a old engine!
