Engine Specific Info and Questions => IDI Engine => Topic started by: bugnut on April 21, 2008, 06:09:18 pm
What k14 turbo should I be looking for. I am rebuilding a stock 1.6td. This will go into my 80 rabbit and just used as a daily driver. No racing and no mods done to the engine. I heard the 1.9 k14 turbo is different than the 1.6 version. Should I just stick with the 1.6 since I am going to be all stock? And if so what turbo part number should I be looking at
Thanks Brian
this one is off of a 1.6TD eco-diesel
I THINK I read that it has the smaller impeller, but I don't know for sure
(http://smellslikefries.com/vwpics/posts/k14%20turbo%20nameplate.jpg)
AAZ compressor is 5cm across the bottom, 3.48cm at the top of the blades.
So I am now looking for these turbos. 068145704d or the 028145703e. It all depends on if I want the larger compressor wheel or not.
Ok dumb question #49 (in an open ended sequence...)
I'm still getting up the curve on everything TD - what difference does a larger compressor wheel make?
DD
