Engine Specific Info and Questions => IDI Engine => Topic started by: oldskool rich on April 17, 2008, 08:32:59 pm
ive heard of a few people doing 1.7s and i want to hav a go.
my plan is, AAZ block, 1.6 crank (lightend/balenced), PD con rods, AAZ pistons (ceramic coated) obviously the compression ratio will be all wrong because of the shorter crank stroke.
if i cut the top off the AAZ block it would sort thing out, without buying custom rods 8)
will this work????????????????
How thick is the block deck vs. half the difference in stroke? Too much shaving and you'll be in the water jacket.
Longer rods?
Chris
i dont know if theres enough to cut off, was hoping sumone will know, are there any stock rods that will fit?
I have considered doing something like this, but with a forged 92.8mm crank out of a '93-'95 ABA. I've done some calculations, and with a 1.9 head, the compression ratio drops to around 20:1 with the stock rods and the thinnest AAZ metal head gasket available. You'd have 1.84 liter engine with a little better revving capability and still have decent torque. The compression ratio is also better suited to super-high boost applications.
low compression ratio would be great for racing applications (more boost :twisted:) as the high compression ratio was designed for great cold starting. an intake air heater would probably help out a lot for those colder starts
so how much should i take off the block? i would like to run mega boost but at the same time i dont want to be tring to start it up for hours each day, its still a daily driver.
i am collecting the block next week, and im gona get the top skimmed off strait away, so cud do with some advice, also is there another IDI piston that has a wider bore than the 1.9 but will take the same rods so i cud bore it out to get more torque?
YouŽll have to cut the block 4mm minimum...
ok 4mm, will that lower my compression? how much difference to stock 1.9 is that? does anyone know how wide the 5 pot pistons are? will they fit the aaz rods?
there must be somthin that will fit :?:
i was thinking that to help me start up maybe a could use a more powerfull starter motor or a 24volt battery, any sergestions?
http://www.brick-yard.co.uk/VehicleSpecific/T3/info/enginedata/dsl/KYdata.htm
Thanks for the link... this is the first time I've seen this:
Dynamic Timing AVL-bosch-Souriau-sun-VLT4139 15* +/-1* @ 900 RPM
One level up from last link.
http://www.brick-yard.co.uk/VehicleSpecific/T3/info/enginedata/engine.htm
Check JX
8)
wow that is amazingly helpfull, that saves me asking about 100 questions
dont supose theres one of those data lists for every car in the world with a good seach engine? :lol:
There is yes.
I have it at work.
Its called Autodata!
It comes on a CD now, go check e-bay, theres bound to be a cracked copy of it somewhere.
I mailny fix older cars and vans, so upto 2003 is fine for me, thats what I have, infact, no, I recently found 2006, but I have no idea where it is now or I would run you a copy off.
ok so ive took everthing off my dona engine now, im ready to get it cut down, just not sure how much by, the differnce in stroke is 9.1mm if i wanted it to have the same CR id hav to cut that much off.
how much difference wud each mm make to the CR?
if i used a thinner gasket cud i cut less off?
i wud like sumone smarter than me to tell me how much i shud cut off and what gasket, i want it to start up fairly easy and be able to run as much boost as possible :D
sorry i dont want much do i :lol:
From what I remember of my block, I don't think you will be able to cut off enough to have a high enough CR to be able to start it. The passages start to really open up not all that far down.
i know they do, i think i can get away with about 5-6mm, if i end up in the water jacket i supose i cud just weld a bit of support across the top, i cant afford custom rods so i dont have much choice :cry:
plans hav all been scrapped
it wudnt work :lol:
cant believe no one thort of the timing, if the block is shorter the belt will be too long and the pullys will be different distances apart. :roll:
think im gona just lighten a tdi crank, fly wheel and use pd rods ect
anyone know of a VNT20 for sale? ill swap for a mental supercharger?
does anyone know of a super thick realy strong gasket i cud use to lower my CR?
You could use a 1.6 timing belt as its 2 teeth shorter than the 1.9 AAZ one.I'm using a 1.6 timing belt on my AAZ but its for other reasons.
