Engine Specific Info and Questions => IDI Engine => Topic started by: turbosuzi on April 06, 2008, 05:42:12 pm
Title: wont start and intermitant vac on ehhaust
Post by: turbosuzi on April 06, 2008, 05:42:12 pm
I installed the 1.6 into the suzuki samurai and set timing(it is still in time) primed the fuel system and cranked, no start. Hooked up the remote ignition and there was diesel vapor and air out the exhaust manifod but also there was in intermitant vacuum when I put my hand over the exhaust.I took valve cover off to verify that I did not have the cam off by 180deg and cranked it and there was some white smoke coming out of the oil returns. the head is  a hydro on mech block. I s there any possibility that the valves are not working properly due to lack of oil pressure? Or am I should I be looking at the head?
Post by: jimfoo on April 07, 2008, 06:05:51 am
That's possible. When I put my engine together and had some bad lifters which didn't seem to pump up, I had puffs of air coming out my intake, so I"d bet the opposite is possible.
Post by: jimfoo on April 07, 2008, 06:06:13 am
:oops:
Post by: turbosuzi on April 07, 2008, 08:23:27 am
Is there a way to verify that without removing the head?
Post by: burnt_servo on April 07, 2008, 09:02:50 am
on the bell housing side of the head  there should be a oil pressure sending unit , you should be able to screw a guage into where the sending unit is and measure the oil presure from just cranking the engine over with the starter .
or even just pull the sending unit out and watch for oil to squirt out .
Post by: DonGTI on April 07, 2008, 09:12:19 am
I thought you could only use a hydro block on a mech head and not vice versa due to tappets not being able to fill up with oil...
Post by: turbosuzi on April 07, 2008, 03:34:43 pm
I put the oil pressure gage on and during cranking it reads just under 70psi.
I thought that you could put a hydro head on a mech block, just that the secondary oil drain is blocked off.
I removed the exhaust and the #1 cyl sucks air in and the others seem to blowing whitish smoke out but no firing on any cyl at all.
Is there a way to check the valves form the top without removing the head, I just installed it?
Thanks for all the help.
Post by: Vincent Waldon on April 07, 2008, 04:04:24 pm
It really really really sounds like the cam timing is off... the lifters are designed to work even when collapsed (ie no oil pressure).
Perhaps tell us how you've confirmed the cam timing... we might have a hint or two that may help ??
Post by: turbosuzi on April 07, 2008, 10:27:30 pm
for cam timing I used the cam lock w/cam gear loose, both #1 lobes facing up. pump gear I used the locking pin and timed the crankshaft via timing marks on flywheel and timing hole in belhousing then re tightened the cam gear. I will recheck every thing tomorrow and report back.
I think that I will remove the #1 injector and run a piece of wire through the prechamber to confirm the #1 cyl timing.
Post by: Vincent Waldon on April 07, 2008, 10:50:41 pm
Quote from: "turbosuzi"
Dude you done stole my only hint left   :wink:
Let us know what you find out.... inquiring minds want to know !
Post by: turbosuzi on April 08, 2008, 12:20:18 am
I used the wire trick and it is spot on timed. Now what?
Post by: burn_your_money on April 08, 2008, 09:21:49 am
maybe your pump is 180 degrees out
Post by: turbosuzi on April 08, 2008, 09:40:14 am
The mark on the back side of the pump gear is in line withe the marks on the pump. If it was out 180deg would that cause the suction on the exhaust?
I will recheck the pump and let you know. I am not sure if the pump gear is the original one that goes on the pump so now that you bring it up I'll check that too. Thanks.
Post by: turbosuzi on April 09, 2008, 09:17:10 pm
I checked the timing and the pump  and all is set spot on. Jimfoo wrote on a different thread:   "Clogged oil passages in the engine, clogged filter and faulty bypass. Those are my two main guesses."
If my head got clogged when the oil filter blew would that cause the lifters to malfunction. It seems like some of the exhaust valves aren't closing all the way because there is some suction on the exhaust ports. If that is the case what is the process to unclogging the oil passages in the head? It is the head only because I put is on a different block.? Is this some thing that I can do without removing the head?
Post by: burn_your_money on April 09, 2008, 09:28:23 pm
If that is what you are thinking do a leak down test.
Post by: turbosuzi on April 09, 2008, 09:54:09 pm
good idea. Is it ok to use the injector holes for leak down so I dont have to remove the pump?
Post by: turbosuzi on April 12, 2008, 06:18:31 pm
aired up the cyls. the #1, air coming out of exhaust port and also on the #4.
How should I try to clean our the oil passages and the valves? Can I just remove the cam remove the valve caps and maybe run brake cleaner followed by compressed air?
