Engine Specific Info and Questions => IDI Engine => Topic started by: mrmike on April 05, 2008, 06:44:47 pm
Title: 1.6L diesel head conversion
Post by: mrmike on April 05, 2008, 06:44:47 pm
read below...and get with your teckies..please...
I need pics. please of the gasket (s) overlayed onto  the block.
1.6L hydraulic diesel head and gasket on top of the non-hydraulic block....
and the: hydraulic head flipped upside down with the non-hydraulic (early) gasket
overlayed on that...purdy please....
So this "void"overlaps that water hole and goes to the outer edge of the block, so
the water follows that......
If we use the old style head gasket that "void" between the head and block is
filled by the head gasket,  but additional water holes have to be punched  in the head gasket..??   .if there are more water passages......whaddya say?
I appreciate your help...txs  very much.....mike 305-731-3185
[email protected]
 :D  :lol:  :lol:  :lol:
Post by: RabbitJockey on April 05, 2008, 07:12:58 pm
i made a post a while back about how to do all the different combos, you can put the hydro head on the solid lifter block by using the solid lifter head gasket and then also block the extra oil drain hole on the front of the head.
Post by: truckinwagen on April 05, 2008, 11:31:49 pm
the way I understand it is the same as Trev0rbr, the hydro head with the second return blocked and a solid lifter gasket.
Post by: turbosuzi on April 06, 2008, 08:39:58 pm
I just did this conversion. I cleaned the 2nd (smaller) oil drain w/brake cleaner then filled w/JB putty (not the paste), use a pencil (eraser side) from top to compress putty and eliminate leakage,(you only need to fill about 3/4-1in,   trim excess on mating surface w/rasor  then install as normal.
This is how I did it, it may or may not be the best but it sure beats taking it to a head shop and tapping, plugging, and grinding the hole.
Post by: turbosuzi on April 06, 2008, 08:50:07 pm
I would like to see what a lifted rabbit looks like truckinwagen
Post by: zukgod1 on April 07, 2008, 07:07:40 am
Well crap, sorry mrmike I dont have pics of the gasket on the block but I just completed a solid lifter block/ hydro head conversion with a metal AAZ head gasket.
There are some pics here http://dubnetworks.net/showthread.php?t=1748 of what I did to plug the holes and the extra holes I drilled in the head and block for cooling.
I have seen some pics of the gaskets on the surfaces you mentioned posted here but I dont remember and didnt save where.
