General Information => General => Topic started by: Vincent Waldon on March 29, 2008, 05:00:41 pm
Title: diesel tach signal vs. gasser tach signal... now w/ pictures
Post by: Vincent Waldon on March 29, 2008, 05:00:41 pm
Here's the signal from the W terminal of a diesel alternator at about 1100 RPM:
(http://i197.photobucket.com/albums/aa85/vwaldon/Wterm_1100RPM_distance_web.jpg)
Here's the signal from the coil of a gasser at about 800 RPM:
(http://i197.photobucket.com/albums/aa85/vwaldon/800RPM_1period.jpg)
Not a perfect experiment because my diesel idles quite a bit faster than my gasser, but the idea is to show that the W signal is quite different both in amplitude *and* frequency.
The gasser tach signal is approximately 26 Hz with a peak voltage of around 80V,  and the diesel tach signal is about 200 Hz with a peak voltage of around 10V.
Again, not exactly the same RPM.. but you get the idea... recalibration is in order if you want a gasser tach to work in a diesel.  Or, a converter circuit that does the signal division.... looks like about a "divide by 8" would be a start.  Same goes if you wanted to use a generic gasser cruise control that expects to be hooked to the coil.
BTW, since the signal from the W terminal is a square wave your multimeter on the "AC Volts" setting can detect it nicely:
(http://i197.photobucket.com/albums/aa85/vwaldon/voltmeteronWterminal_web.jpg)
If you had a multimeter with a "frequency" scale you could measure the signal directly.
Filed under "a picture is worth a thousand words",
Post by: RabbitJockey on April 01, 2008, 08:39:18 pm
oscilloscope oh my.  i used to like playing with them at school, i was the only kid in my class that could get anything to come up on the screen haha, i didn't learn *** in that class, how horrible we never even got taught to use those i figured it out myself :roll:   neat to see these,  looks about right since a w terminal plugged into a gas tach says about 4k,  and if u hit the gas it goes to 8 and then flutters all over the place haha
Post by: cal on May 04, 2008, 03:38:32 pm
so with the right resistors etc you could build an in-line converter and not have to touch the gasser tach yes???
if so what do i need??
thanks in advance :)
Post by: Vincent Waldon on May 04, 2008, 03:55:43 pm
Just resistors won't do the trick... you need to condition the signal *and* divide the frequency.
Or you can buy a signal converter.
Or you can recalibrate the resistors on the gasser tach.
Or you can install an optical pickup.
Or you can install a flywheel pickup.
Lotsa options... "search" is your friend in this case.   :wink:
Post by: cal on May 04, 2008, 04:15:46 pm
well i've read the convert your gasser tach thread like 15 times now, my problem is i've got a motometer tach that isn't listed on there and i can't seem to apply the principle to work out the values for mine.
how would you go about making a signal converter then? as i can't find them in the uk :(
Post by: Vincent Waldon on May 04, 2008, 05:56:41 pm
Because the diesel signal is not an exact multiple of the signal the gasser tach is expecting there's no simple way to do this... a microprocessor is required.
Unless you can design, build, and write assembly language for microprocessors the easiest solution is probably to buy an off-the-shelf converter from people who can:
http://www.dakotadigital.com/index.cfm/page/ptype=product/product_id=128/prd128.htm
Post by: Smokey Eddy on November 14, 2008, 10:32:33 am
For those of us that can write assembly language for microprocessors have you tried this already? have you come up with anything vince?  :lol:
Post by: zukgod1 on November 14, 2008, 10:37:35 am
Quote from: "Smokey Eddy"
Oh look he's braggin!!
 :D  :D  :D  :D  :D  :D
Just teasing ya smoke.
Post by: 79rabbit4dr on November 14, 2008, 11:18:21 am
Quote from: "Vincent Waldon"
bookmarked!!!
thanks for all the wisdom Vince!
Post by: Smokey Eddy on November 14, 2008, 11:25:00 am
Quote from: "zukgod1"
 :D  :D  :D  :D  :D  :D
Haha! Just for the benefit of the forum Dan! And you  :wink: can call me Ed
bookmarked too  :P
Post by: Vincent Waldon on November 14, 2008, 01:01:10 pm
As it happens, I have the honour of having written the *only* piece of code that was not Y2K-compliant at our local hospital back in the day... thousands of pieces of complicated medical equipment and the microprocessor-controlled neonatal transport incubator I helped build was the only thing that had a confused clock on Jan 1, 2000.    Good times !
'Course back then we had it tough... no fancy "1"s and "0"s like folks have today... I had to write the whole thing with only "0"s. :wink:
Post by: Smokey Eddy on November 14, 2008, 01:17:13 pm
Hahahahahhah!
Nicceee!!!
