General Information => Troubleshooting => Topic started by: shegel on March 18, 2008, 08:26:10 am
im suspecting a bad hg because of a little oil in the coolant...but it starts up fine and i drive it 100 miles a day with no issues. other than a bad shake that i need to figure out too. my question is this. if the headgasket died then wouldnt the car have too low of compression and not run. also woulldnt there be coolant in the oil....?!?!?!?!?!?
not necessarily. oil/coolant contamination is only a possibility, not a definite. A leak down test will show a bad HG or looking in the coolant reservoir for bubbles with the car running may show a bad headgasket.
It could be the oil cooler leaking or it could be some oil that was trapped in the cooling system and was just freed up by the coolant getting hot.
i dont have an oil cooler i dont think. its for the golf in my sig.
Burn's got it... if you need to find a blown head gasket start with a compression test.
Since you mention a bad shake my crystal ball will predict........ bad compression in two adjacent cylinders. :wink:
ok that makes sence. so i guess i will buy a compression tester.... are the ebay ones ok?
If you go on ebay for the tester check out harborfreight.com. A dude on ebay buys them from that site and sells them for more then harborfreight sells them for. I have a harborfreight one just havent used it yet.
I have used the ebay/harbourfreight ones and they work great.
anyone got a link to this tools site?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=350048177131&_trksid=p2759.l1259
somthing like this
i bought one like that. works good. mostly mechanical so i can't see it being crap
How did they ship?
USPS or UPS/Fedex?
I ask because, I'd never
buy anything cross-border
if they only ship UPS.
Too may extra/unexpected
Charges.
here it is:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93644
The one i bought from harbor freight actually comes with more adapters for the same cost just so you know.
