General Information => Troubleshooting => Topic started by: Methanolab on March 15, 2008, 12:57:06 pm
Title: A Few Issues At Once
Post by: Methanolab on March 15, 2008, 12:57:06 pm
Hey All,
     I got a couple problems and need some help if you please.
Vehicle: US 1983 VW Quantum 1.6 TD Wagon 235K mi. Averages 42 mpg 0.5-1L oil consumed/leaked every 400 mi.
     I have put 100 miles a day on this car since I bought it two years (55k mi) ago. I took it on a 1500 mi trip two weeks ago and noticed fuel mileage down to 35-38 mpg. And increased oil consumption/leakage. About 1000 miles in it started idling really rough and oil consumption went up to 1L per 100 mi. It is leaking much more oil but I don't know if it is consuming more as well. Above idle it runs fine, maybe a little lack of power. It is very hard to start and sounds like it is rattling when I turn it over, the whole thing shakes. It turns over faster with the cold start lever pushed in and that is the only way it will start. While giving it fuel and with the cold start lever in, it takes a half a minute of cranking to get it to start and it lets out a larger cloud of dark smoke than it used to. Then it runs roughly and doesn't seem to respond very quickly to the accelerator for a minute or two.
     I checked the glow plugs and they are conducting electricity. I loosened the fuel injector unions one at a time at fast idle and each one reduced the motor speed the same. It made an 8 inch puddle of oil in 1/2 to 1hr of idling, about a drop a second from the oil pan. Once the motor warmed up the idle smoothed out a little but was still rougher than normal. I raised the idle adjustment so it idles smoothly now and doesn't seem too fast. The idle has always seemed too low. The motor used to shake before I replaced all the mounts about a year ago. They couldn't have gone bad again already could they?
     I imagine I am loosing some oil from worn rings. I meant to check the compression after I bought it because of age, miles, and oil consumption but it ran so good I didn't bother. Obviously I have a bad oil leak now, maybe crank shaft seal? I will need to clean the whole motor compartment again to track it down. My dipstick tube seal (replaced a year ago) might have gone bad again? I suppose blowby and crankcase pressure might be making it worse.
     Could lack of compression be making it so hard to start and causing the rough idle and oil consumption/leaks? Or poor spray pattern from the injectors? Does it sound like there is something wrong with the cold start system or the injector pump? I get an air bubble cruising down the fuel line to the pump every once in a while but it doesn't seem to effect the motor. Sorry for the long tale of woe, I know there are some real gurus around here. Any help would be greatly appreciated, I love this car. Thanks,
--Chris
Post by: jtanguay on March 15, 2008, 01:13:49 pm
since it has mechanical lifters, you should probably adjust the valves.  they *should* be checked every 15'000km's or so. or is it miles? all you need to check is a feeler gauge that you stick between the cam lobe and the valve lifter when the lobe is pointed up.
rough starting, crappy idling, bad fuel economy, and eventually a no-start situation can occur.  the oil consumption could be from bad valve seals or stuck/worn rings.
hope that helps!
Post by: Methanolab on March 15, 2008, 01:24:04 pm
Thanks, yea I check the valve shims faithfully every six months or so. I need to do that again now. It would be nice if that was all that was wrong. I have never had to make any adjustments when I checked them in the past. I really hope its not the rings. Thanks
Post by: jtanguay on March 15, 2008, 01:27:00 pm
if you could check the compression that would give a good idea of what might be going on.  i bought a kit off ebay that was cheap, but looks to be of decent quality.
Post by: Methanolab on March 15, 2008, 02:48:31 pm
I will do that next. I hope to have a chance in the next week or so. I have been very busy lately. If you think of it, please keep an eye out for the results. Should be within two weeks.
Post by: Patrick on March 15, 2008, 04:09:44 pm
I'd be looking at the timing and the fuel filter if it was mine, as well as compression.
Post by: Possum79 on March 17, 2008, 10:26:23 am
If you get a compression tester off of ebay dont spend more then 24.99. I looked at them once and went hey thats the EXACT same kit you can buy from harborfreight.com for 24.99. Only ebay has then for like 29.99 and 18 to ship. Check harborfreight.com before you buy. May save a few bucks for the same kit.
I bought one from harbor but havent used it yet.
Post by: zukgod1 on March 17, 2008, 10:37:37 am
Quote from: "Possum79"
Bought mine from there, used it a couple times now. Seems to work fine.
Post by: Methanolab on April 05, 2008, 06:58:16 pm
Finally got to work on it today. First I checked the valve timing and the crank timing. They were pretty good but I tightened the belt (its due to be replaced). Then I checked the injection pump timing and it was at 0.80 instead of 1.0 +/- 0.07. I adjusted the pump timing. The valve clearances were all good. It started a little better but was still sputtering a little rough and smoking. I changed the fuel filter and filled it with ATF and that just about got it back to normal. Later I ran a can of injector cleaner and more ATF through it. Seems to be running pretty good now. Still has a decent oil leak but I don't know if it is any worse than it used to be.
Next I am going to clean the motor and try to find where it is coming from. It looks like the valve cover, the oil filter seal where it connects to the block, the dipstick seal at the block, the front main crank seal, and maybe the oil pan seal. There is also an exhaust leak at the manifold. Didn't get to check compression but I still hope to. Is there a good thread or sticky around on a crank case ventilation modification? That might reduce the pressure on the oil seals wouldn't it? The pressure at the oil fill hole seems to have gotten stronger in the last year. It blows a heavy rag now. Thanks for your input.
--Chris
Post by: Methanolab on April 17, 2008, 03:18:38 pm
Ok compression results, read 'em and weep: (with me)
    PSI   / +oil
1: 375   /  600
2: 225   /  595
3: 375   /  475
4: 30     /  175
Post by: Possum79 on April 17, 2008, 04:38:38 pm
I weep for you  :cry: . I still have yet to check my compression. I have new nozzles for my injectors and i want to do it all at the same time but i have yet to build a pop tester.
Im scared I may end up with horrible results.
Time to re-ring her bud.
Post by: Methanolab on April 23, 2008, 06:42:24 pm
What do you all think, should I rebuild it, sell it, part it, junk it, rebuild the motor for something else and junk/part the body?
Post by: Possum79 on April 24, 2008, 08:38:05 am
To me it depends on what you need. If you like the car and want it rebuild and reuse. If you dont sell stuff out of it.
Post by: jimfoo on April 24, 2008, 08:44:06 am
Rebuild it. If you sell it for something else, who's to say you won't have to soon do work on it? If you rebuild it, you know everything is good.
Post by: jtanguay on April 24, 2008, 09:26:49 am
Quote from: "jimfoo"
i agree... what if its just a valve that isn't seating properly?  get the head professionally done or just buy one from www.dieselvw.com with new valves and lifters, and then buy new rings for the pistons.  might not need to bore it out.
Post by: Methanolab on April 24, 2008, 11:32:27 am
Quote from: "jtanguay"
Ahh, they don't have 1.6TD heads for early Quantums
Post by: Possum79 on April 24, 2008, 12:22:02 pm
Prothe might actually have something that would work. call him or email him. Hes on this board and he is the dieselvw.com person.
Post by: Methanolab on May 17, 2008, 06:51:41 pm
I pulled the head today and got more specs, still thinking about a rebuild but it looks like it would require boring and oversize pistons or sleeves if thats an option. I'm thinking it isn't worth the trouble with the shape the rest of the motor/car is in and diesel cost is now cost/mpg equalized with regular unleaded.
The cylinders look decent and smooth visually but they are just a hare under their limits for wear (0.075, limit 0.080) and out of round (0.038, limit 0.04).
Anyone know how long new rings would last with the motor in this condition?
The valve seats all look pretty clean and it looks like they are closing all the way but I have never inspected valves before. Nothing like what I would expect a burnt or stuck valve to look like. A few of the exhaust valves are coked-up on their bottoms and when I scratch them it turns white. Any advice? Thanks,
--Chris
Post by: Patrick on May 18, 2008, 06:06:02 am
Pop the piston out that had the worst compression, I'd bet on broken rings. Cleaned up and re- ringed might get you a few more years. Cast rings won't last as long, bet they should conform to an out of round bore better.
Post by: Methanolab on May 26, 2008, 02:55:06 pm
Do you know if I can just drop the oil pan, unbolt the connecting rod and pop out the piston through the top with the motor in the car?
I assume  that you are recommending I use the NA rings instead of the TD rings and not worry about reconditioning the cylinders correct? You don't have a part number or a source do you? It looks like ETKA lists the same part number for the NA and TD rings but I have heard there are different ones.
Post by: jimfoo on May 26, 2008, 03:13:30 pm
Maybe you could get total seal rings in a size slightly bigger to better seal. They had a couple different sizes that were close when I got my 1.mm oversize pistons. Or get them big and file to fit.
