Engine Specific Info and Questions => IDI Engine => Topic started by: Powered by Spearco on March 12, 2008, 12:34:50 am
Same as above. Block is a mechanical lifter, 12mm bolt size. Are the bolts long enough for the 1.9 AAZ head.
They should.
I think that the block on the 1.9 is taller and the heads are the same, right. So the bolts should be the same?
yes, they work OK on aaz and also on tdi vp
Thanks! :D
