Engine Specific Info and Questions => IDI Engine => Topic started by: dokarex on March 03, 2008, 06:36:03 pm
Hi
Finally found a 1.9TD to replace my 1.6NA in my Doka.
Couple of Questions
1) have to switch oil pans: should I order the 1.9 one or the 1.6 gasket
2) can I run the alt and water pump off the same belt and be rid of the serpentine belt? (no ps or ac) Just switch the pulleys from on engine to the other??
you need a Vanagon oil pump and pan, the motor lays over so far that a regular oil pump wont work.
you also need the to consider the turbo arrangement, manifold selection, drain lines, injector pump clearance, exhaust mods intake route with filter and intercooler, and on and on..
The van has the 1.6na in there now (has oil pan)
no IP clearance its a Doka
doh!
well on the oil pan you'll have to have a return line bung welded in..
If you don't mine could you explain the return line? From the turbo?
No inter cooler (yet).
Hey myke
could you expand on this"well on the oil pan you'll have to have a return line bung welded in.."
thanks
anything else? :D
So I have to:
Switch pulleys from 1.6 to 1.9 to drive alt and water pump
Switch oil pan and oil pump
New drain line from turbo to oil pan
Switch pressure plate
Make exhaust and air intake/filter fit
Match up wiring
Can I switch the oil pick up tube or do I have to switch the whole oil pump?
