Engine Specific Info and Questions => TDI Engine -General Info => Topic started by: scopefrfd on May 31, 2004, 04:55:39 pm
Title: KKK K03 hybrid turbo questions
Post by: scopefrfd on May 31, 2004, 04:55:39 pm
I was just comparing the KKK K03 that is on my A3 1.9tdi engine vs a KKK K03 that came off of a passat 1.8T and I noticed that the compressor side of the passat K03 is noticeably bigger. Is it worth swapping out the tdi compressor for the gas compressor/housing? The turbine side looks the same to the naked eye. I haven't disassembled them yet. Also is it a could idea to swap out bearing housings. The gas version is also water cooled for extra protection. I would just swap out the turbine housing sections if the turbines are the same and bam more boost.
Post by: dieseltech on May 31, 2004, 05:09:32 pm
the way the tdi is stock it has full boost at 1900 rpm. if you switch to the bigger one(passat ko3) you will loose the 1900 rpm full boost. it is going to be in the 2300-2500 range. the reason the tdi housing is smaller is because the redline is 4500 so they wanted boost earlier so you can have usable power, if you put the passat ko3 on you will run out of rpm before the full boost would be reached. in first gear this would show up as massive turbo lag. the higher gears would not be as noticable.
