Engine Specific Info and Questions => IDI Engine => Topic started by: autobahn on April 08, 2005, 12:59:15 am
Title: Motor mounts on 1.9TD
Post by: autobahn on April 08, 2005, 12:59:15 am
Wondering if anyone has put in aftermarket mounts on their car and if the vibration was acceptable? I'm doing an 02A swap in my 96 jetta and we thought we'd go with:
KCD or turn2 front upper and lower
new oem rear upper/lower
new oemVR6 tranny mount
I'd really like to know if using all KCD or turn2 would be too hard.
Post by: QuickTD on April 08, 2005, 06:44:24 am
I've heard that the turn two front mount will froth your latte. This was coming from a TDI owner, and the TDI is quite a bit smoother than the 1.9TD. I've heard others say that a full set of urethane mounts on a diesel will liquify your guts at idle. It would keep you regular I guess... :D
Post by: autobahn on April 10, 2005, 01:50:44 pm
thx, i'm gonna try the vw solid rubber vr6 tranny mnt with turn2 lower front and upper rear and the rest new oem. i'll let you know how that works
