Engine Specific Info and Questions => IDI Engine => Topic started by: haybayian on February 28, 2008, 03:50:58 am
Title: Coolant temperature sensor. Where?
Post by: haybayian on February 28, 2008, 03:50:58 am
Sorry Guys for asking such a pedestrian question but unlike most of you I have not seen  my AAZ together and running before since it comes from a reman shop. I am not clear from my Bentley manual what the water temp sensor is . Bentley says it should be on the side of the head. Is it the only place? .  Is there a threaded hole somewhere in the head (back) where the sensor could be screwed on?
Thanks.
Haybayian
Post by: Baselyne on February 28, 2008, 04:28:46 am
should be on the right side of the head while your facing the engine from the front of the car....
There will be a front an a side water neck/flange and im sure you'll find a little golden sensor/nub type thing on side water flange... I do beleave its on that flange where the hose from the heater comes from!~
another member may have a better description and I may be totaly off but I think thats where you'll find it!
just trying to help!
good luck
Post by: burn_your_money on February 28, 2008, 05:13:15 am
I think it can also be on the front of the head. It does not physically attach to the head, but rather attaches to a coolant flange that bolts to the head
