Engine Specific Info and Questions => IDI Engine => Topic started by: moTthediesel on February 10, 2008, 09:01:56 pm
Title: miminum piston projection?
Post by: moTthediesel on February 10, 2008, 09:01:56 pm
Finally started putting my 1.6 TD back together today at long last. I bolted in one of the new second oversize Kolbenschmits in the bored out block to measure piston projection before I ordered a new head gasket.
Using a dial indicator I got a projection of only .019"! According to Mr. Bently, even for a 1 notch H.G. you should have a projection of between .026" and .036".
My question is: is that amount of projection unusual, and will it have a negative effect on cold starting?
moT
Post by: zukgod1 on February 11, 2008, 08:34:03 am
I'm in the same boat.
I think I had like .23 on mine.
I had already bought a 3 notch and rather than wait (I should have ) I just installed it.
I really doubt it will make that much of a difference in a fresh engine. Now if it was older and had some miles on it I would be more concerned.
Post by: RabbitJockey on February 11, 2008, 01:59:49 pm
just make it better for boosting i suppose
