Engine Specific Info and Questions => IDI Engine => Topic started by: neich on April 02, 2005, 12:42:42 am
Hi all,
I have a T3 syncro with an AAZ swapped that still uses the fuel pump from the old 1.6TD (JX). I am going to rebuilt the pump and I also want to change the fuel lines. The problem is that I don't know which ones shoul I buy. The ones for the AAZ or the ones for the JX ?
My guess is that the body of the 1.6TD fuel pump is the same that the 1.9TD, so I should buy the AAZ ones. Any hint ?
Thanks
Nacho
You will need to use the AAZ lines. They fit the tall two-spring injectors properly. You don't really want to buy them though, last I heard they were over $100 each at the dealer...
