General Information => Troubleshooting => Topic started by: BioDieselVW on January 23, 2008, 07:15:47 am
Title: T-3 Turbo Install
Post by: BioDieselVW on January 23, 2008, 07:15:47 am
Will a T3 turbo off a Mercedes Benz 300TD fit or work as an upgrade to my 1.6TD. Will it not have the right internals to work with the vw 1.6? or will the 1.6 have a hard time spooling it? Is it even a direct bolton? If anyone has tried or is running this setup feedback will be much appreciated. Thanks Paul
Post by: burn_your_money on January 23, 2008, 08:18:48 am
It's not a direct bolt on due to different turbo and downpipe flanges from my understanding
Post by: subsonic on January 23, 2008, 09:40:18 am
Thats what I am putting on mine.  My engine will flow a lot more than stock though.  I have a AAZ head that Dave has done the big port job on and a giles pump to go with it.  You also need to check which turbo you have, as there are 3 variations of that turbo on the 300td.
BYM is correct. It will not bolt up with out modification.  I went with a different exhaust manifold.  A ATP 8V turbo manifold. Here is a link to what it looks like:
http://www.aptuning.com/products.php?productid=718
Post by: BioDieselVW on January 23, 2008, 03:22:05 pm
Thanks, I kind of figured it was to good to be true for it to be a direct bolton. Thanks Paul
Post by: BioDieselVW on January 24, 2008, 06:40:39 am
How are the T3 turbos that came with 1.6 TD. Are they too laggy? Or do they spool well and make good power on the 1.6TDs?
Post by: burn_your_money on January 24, 2008, 12:50:17 pm
Quote from: "BioDieselVW"
From my experience on the 1.6 the spool around 3000 RPM with stock settings and light driving
