Engine Specific Info and Questions => IDI Engine => Topic started by: cal on January 05, 2008, 03:49:50 pm
Title: boost controllers?
Post by: cal on January 05, 2008, 03:49:50 pm
do they work on 1.6 idi's???
thanks in advance guys :)
Post by: jtanguay on January 05, 2008, 03:54:29 pm
yep.  they'll work on any wastegated turbo setup.  they basically limit the amount of charge air going to the wastegate to 'fool' them into thinking you're at a lower pressure.  this makes the wastegate open at higher psi, and should be adjustable.
they tee into the hose or metal line going into the wastegate. (looks like a can)
Post by: cal on January 05, 2008, 04:01:52 pm
worth getting one???
Post by: subsonic on January 05, 2008, 06:24:18 pm
Depends.  What do you want to do?  How much boost do you want and what is your turbo set-up?
